rebuild help
rebuild help
i posted a thread explaining my problem and i also have a few questions on how i should rebuild if it is necesary....(funny, a part of me is like oh yeah!!! more power ...and the other part is like damm it!!!, no money!! )
ok, here is wat im thinking of doing... oh, i also have about 106k miles
SLP heads/cam with 383 rotary assem., valvetrain, injectors... prept stock block
383 Short block by ARE, lingenfelter, ported heads and a new cam/valvetrain....
Of if there is a long block that is reasonably priced, then mabe...
if anyone has any advice or comments, please feel free.....thanks!!
1 Post
Originally Posted by obZidian
anyone..........i want to see if anyone had anyecent rebuilds and see wat worked for them...
Originally Posted by Z28Venom
Do a search.. for REBUILD.. You won't believe all the info you'll find..
there is even another thread on the NEXT PAGE about rebuilding our motors in an economical fashion, b/c I am in a similar position(except I am doing it b/c I want to avoid breaking a part, not b/c i did. hopefully i will save some money this way, not be as rushed. do a search like Venom said, you'll **** yourself when you see what comes up. i got ten pages of results when i just used the word "rebuild" in my search.
Yeah I have 115k on my stock motor and stuff started to break, first it was oil pressure sending unit, then oil pump, then a knock generated from the valvtrain. so I just pulled the motor and I am in the process of rebuilding it. Already mic'd the block, pistons, checked the rods and crank, all seems to be good, well other than the number 5 cylinder is actually a little smaller than the rest. So everything is getting cleaned and i will rering the pistons put new cam, rod, main bearings, new oil pump,lifters, and all gaskets and seals and I spend around 600 bux and it will be back together in a couple of days and ready to drop back in. hope that helps.
