misfire.. help..
Old 10-24-2004, 05:17 PM
InsomZ's Avatar
Default misfire.. help..
yea i've done a search.. i can't figure this out..
i've replaced all the spark plugs..
new set of taylor spark plug wires..
bought a new coil pack and played musical chairs switching it out..
pulled both valve covers and all the springs look fine
i can't figure out where this damn misfire is coming from
i have a z06 cam and all the bolt ons.. tuned by mti.. the misfire codes were turned off i guess cause w/ any cam it sets off misfire codes.. but not like this ..
its made the car a pain in the *** to drive.. i'm starting to hate it.
Old 10-24-2004, 06:38 PM
Slacker's Avatar
It's your taylor wires. They look nice but I went thru 2 set's. Each set had 3bad wires. You need to OHM them out, or just put your stock one's back on. When I put the header's on I purchased a new set & ohm them out before install & 3 of them were off the charts. I ended up sending them back & the next set also had some bad wires. I ended up buying MSD's with no issues. A partner of mine was also chasing a misfire issue & found a couple of bad taylor wires.
Old 10-24-2004, 07:16 PM
InsomZ's Avatar
cool thanks.. i'll try that next.. stock set of plug wires :/
Old 10-24-2004, 07:20 PM
98Blubrd's Avatar
how old r your O2 sensors. I replaced mine and car runs great again.
Old 10-24-2004, 07:25 PM
InsomZ's Avatar
their actually pretty new.. replaced them after the headers swap
Old 11-06-2004, 01:41 PM
InsomZ's Avatar
Update! you were right it was the Taylor Spark plug wires.. ordered OEM plug wires put them on and the car runs like a champ!! misfire completely gone..
i would definately never recommend Taylor Wires now.. these 8.5mm fell apart when taking them off.. crappy *** wires
Old 11-07-2004, 05:04 AM
PREDATOR-Z's Avatar
MSD or bust!!!!!!
