2 many ways to go???
Old 10-25-2004, 12:07 AM
ws62001ta's Avatar
Default 2 many ways to go???
ive been wasting so much time thinking of what mods i can do to my car, ive looked at 3.73 then a 3500 stall then cam... i just dont know what to do. if anybody has some ideas that yall can post of what to do first and stuff, im trying to stay away from the cam, for 1 its $$$ but i also want that BADASS LOBE! so plz help out....skeeter
Old 10-25-2004, 12:19 AM
cyphur's Avatar
dude you need to sit down and figure out what you want your car to do. what are your goals? street, strip, is it your daily driver....what? you need to develop some sort of plan. also, READ. read all of JRP's guides. if you can sit down and read all of those guides, and all of his stickies, THOROUGHLY, and can still say you have no idea what to do.....you've got some problems. jrp has put a lot of work into those, and should steer you in the right direction. you need to be a little more coherent when you ask these questions, a bit more collected. people aren't going to sit down and spend all this time coming up with different ways to mod your car...they're busy enough working on theirs!! and for the few that might, you've not provided enough info. think this out a little bit, read all those guides and come back and re-post and people will be better able to answer your questions.
i will say one thing. hands down, a stall convertor is the best mod you can do for an a4. period.
Old 10-25-2004, 12:24 AM
ws62001ta's Avatar
aight thanks man
Old 10-25-2004, 12:49 AM
PREDATOR-Z's Avatar
Yeap, stall first, I assume you have 3:42's so that should be fine for now.
I recommend VIG 3200, or TCI 3500, both a very streetable (I had TCI, now switched to VIG), VIG is a bit looser but bites harder than TCI.
Old 10-25-2004, 12:57 AM
LSUxBlake's Avatar
You have about 5 or 6 threads asking the same question in a roundabout way.
Old 10-25-2004, 01:00 AM
ws62001ta's Avatar
sry im all over the place.
Old 10-25-2004, 01:06 AM
God of Thunder's Avatar
i thought all a4's came with either 3.23's or 2.73's? did it change in the later years?
Old 10-25-2004, 01:12 AM
PREDATOR-Z's Avatar
As far as I know, SS and WS6 came with 3:42
(BUT I COULD BE WRONG)
Old 10-25-2004, 01:18 AM
cyphur's Avatar
P-Z, I always thought WS6's came with 3.23's. I owned a '98 Formula WS6 and I swore thats what she had. Could be wrong? Of course mine was an A4. My regular T/A is an M6 now and has 3.42's.
Old 10-25-2004, 01:19 AM
ws62001ta's Avatar
does anyone know if ill pass emssions in tx with a hotcam and all the things in my sig???
Old 10-25-2004, 01:22 AM
LSUxBlake's Avatar
I'll be honest with you. You just need to use the search button. You have too many threads asking too many random questions that have been beaten to death in this forum. Search, and if you can't find an answer, post.
Old 10-25-2004, 01:30 AM
PREDATOR-Z's Avatar
226/236 .525/.525 110 LSA
If this is the ASA hot cam you are talking about and they sniff test, NO you'll not pass emmissions.
This cam has a positive degree of overlap at .050 of +11
Check MTI Stealth II it has a minus -10 degree of overlap at .050 and will pass with flying colors. A TR224/ 114lsa will pass if properly tuned.
Old 10-25-2004, 01:32 AM
Paulz2820's Avatar
GU3 code is 2.73's for A4's
GU5 code is 3.23's for A4's
ALL 6 Speeds have 3.42's
