cam swap over .600 what springs??
Old 10-25-2004, 02:14 PM
8 second mod
Noyzee's Avatar
Cool cam swap over .600 what springs??
im doing a cam swap in my buddies 99 TA,he is looking for good stuff, but not brake the bank stuff. good springs for a 601 cam 230's
stock heads and shortblock. what does everyone sugest?
I will be pulling the heads to clean them up a bit, kind of a home port job, he's looking to make over 400 with cam and stock heads auto stock converter. with all bolt ons
Thanks again
Old 10-25-2004, 02:36 PM
black_z's Avatar
I will be going with a cam over .600 on stock heads and will be using patriot duals.
8 second mod
Noyzee's Avatar
they seem to be the best priced.
Old 10-25-2004, 02:52 PM
luv2spd's Avatar
Yeah the patriot golds are good to .650. He would be fine using those.
Old 10-25-2004, 02:59 PM
XTrooper's Avatar
PRC (Precision Racing Components) dual springs which are good to .650" valve lift.
I just ordered a set myself from our sponsor, TSP, to replace my 2 year old REV springs.
Old 10-25-2004, 04:15 PM
Cstick's Avatar
If you call TSP they seem to like the Percision Duals, I have the set as well. $289 for the dual springs, titanium retainers, new seats, GM seals. I thought I read they were good to .660, but close enough neither of us will need that much anyway.
Old 10-25-2004, 04:29 PM
gettinthere's Avatar
Like said above, the PRC's are good to a .660 lift and generally about $10 cheaper than the PP golds. I'll be running the PRC's on my heads.
Old 10-25-2004, 04:42 PM
critter's Avatar
What about springs for 0.690 lift?
Old 10-25-2004, 04:48 PM
Redlinez's Avatar
690 lift???? Wow!! I have the Patriots and I'm happy as I can be. My MPH didn't change in the least as I was worried they were stiffer than the Rev's.
Old 10-25-2004, 06:17 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
PRC does not make Patriot's springs. Both companies offer a great spring kit & you can't go wrong with either setup!
We offer the PRC kits designed to fit stock locks! Alot of customers have requested kits that use GM locks so that's the way this kit was designed.
The PRC titanium retainers will not fit Crane springs however. The PRC kits retainers were designed to only fit PRC springs in a effort to make a great fit!
Here's a pic of the kit!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 10-25-2004, 06:25 PM
XTrooper's Avatar
Thanks for that correction, Jason.
P.S.- When you get a chance, please e-mail me my tracking #.
Old 10-26-2004, 12:14 AM
GrannySShifting's Avatar
Yes but which company makes botht eh PRC and Patriots?
Old 10-26-2004, 07:04 AM
8 second mod
Noyzee's Avatar
cool, sounds like either way i cant loose.
i can get PP entire kit for 250 new, so thats the way i will probably be going
Old 10-26-2004, 09:20 AM
which of those sprign kits has the internal steps on the retainer radius to the same edge as the spring coil? What the most aggresive cam/lobe setups run without problem on each of these to date?
just like Comp said 918s are good to 650 lift... Im skeered of doing that.
Old 10-26-2004, 09:48 AM
.690 lift ?!?!? You may have to contact a sponsor directly. I've never even seen springs advertised that high.
Old 10-26-2004, 10:03 AM
Theres .740 lift cams all the way up to 1.0 Im sure
Old 10-26-2004, 10:50 AM
8 second mod
Noyzee's Avatar
the comp 921's are rated pretty high, after that i would say some work to the heads may be needed for a bigger spring
Old 10-26-2004, 11:43 AM
Gunnar@Patriot's Avatar
Our original Patriot Gold springs are available from any of our retailers for $279.50 plus shipping.
Old 10-26-2004, 11:47 AM
8 second mod
Noyzee's Avatar
you guys in new england?
i see the patriot guy there,
they are kicking *** this year. i live in mass.
Old 10-26-2004, 02:21 PM
smithsc's Avatar
When it comes to springs and saving a couple of bucks, I say pay a little extra and get the protection and durability from a set of Comp 921's.
"It's either pay me now or pay me later, which would you rather do!!!"
Seriously, I don't know if there is a dollar's worth of difference between them, but I'm banking on the Comp's living up to their price!!
Steve
