Who has revved their H/C 346 over 7500? With stock rods?
Old 10-26-2004, 12:55 AM
Stu'sWS6's Avatar
Default Who has revved their H/C 346 over 7500? With stock rods?
Just as the subject states: I am looking for those who have revved their 346's past 7500 on a regular basis.
I have a 346 with Wiseco's and rod bolts-just wondering if anyone has run theirs that hard with the stock rods. My new combo should peak over 7k-I don't want to get into the shortblock again until next year(building a new motor.) I know that the rods are the weak link. I don't need opinions on that-just wondering who has done it, how long it lasted, and how long it took you to clean up the mess afterwards.
I've seen plenty of folks running in the low 10's and high 9's on the squeeze with the stock rods; how many are turning some R's as well?
Old 10-26-2004, 12:58 AM
kickassT/A's Avatar
no one who has lived to tell about it. if youre buidling a new motor that you plan to swing to 7500, then why no rods? thats playing russian rolete with a semi automatic
Old 10-26-2004, 01:00 AM
MUSTANGEATER's Avatar
I think it's doable with an ARP Rod Bolt, but that's just me.
Old 10-26-2004, 01:23 AM
DOC OTIS's Avatar
He is talking about the shortblock he has now. He has intentions of building a new shortblock, eventually, that will have good rods in it. Just trying to figure out if the block he has now will last until the new one is done.
TTT
Old 10-26-2004, 01:26 AM
MRI-TEK's Avatar
From what I get, O1-Z has been spinning his motor to around 7000 "completely stock bottom end " I guess over several hundred passes & also on the dope from what one of his posts say .. Like you stated , the rods are the weakest link. I broke 2 rods @ around 6800 rpm , but with alot of dope !!! My motor lasted about 7mo . going to the track every other weekend .. Good luck with your new combo .
Old 10-26-2004, 01:33 AM
Stu'sWS6's Avatar
I have stock rods, wiseco pistons, and arp bolts in my current 346. The new motor will have forged h-beams at the least, prob. billet rods.
I will need to get the tune dialed in before it will run well over 7500-It should peak around there once it's done. I hate to rev it that high with the stock rods, but I know that I won't be happy with the numbers unless I do.
Old 10-26-2004, 02:09 AM
I can shift faster than you.
Jason99T/A's Avatar
I have turned a stock shortblock w/ ARP rod bolts 7500rpm on many occasions, with many different setups. The rods really are not that bad. It is the bolts that are the weak link the entire equation.
RPMs do kill motors, so don't expect 100k+ miles out of it.
Jason
Old 10-26-2004, 02:44 AM
Stu'sWS6's Avatar
Jason
I don't expect it to last forever; I just don't want to spend anymore money on it right now. I have plans for a new shortblock after next season.
Jason-How high are you shifting your new setup? Mine is very similar.
Old 10-26-2004, 10:43 AM
z98
z98's Avatar
So don't go spinning it to 7500 RPM.
Change out the rod bolts and stay behind the bleeding edge (i.e. the crazies who really push stock bottom end cars).
Old 10-26-2004, 12:57 PM
ONEBADWS6's Avatar
How do you tune a car past 7200?
Old 10-26-2004, 01:45 PM
Jason99T/A's Avatar
Revlimiter is set at 7600 on my new setup.
Old 10-26-2004, 01:55 PM
Casperws6's Avatar
my friend shifted his a4 to 8300 rpm on completely stock bottom end as well as a 200 shot. than the motor
Old 10-26-2004, 03:11 PM
777's Avatar
Dear Lord!!
Old 10-26-2004, 03:41 PM
DONAIMIAN's Avatar
I thought the stock PCM couldnt control the motor over 8k
Old 10-26-2004, 04:31 PM
strokedls1's Avatar
Stock pcm only goes to 8000 rpm.
Old 10-26-2004, 07:07 PM
Louis's Avatar
for that split second over 8, it has no idea where the hell it is.
Weve gone to 8, but not past it. There really is no point because you are simply out of air if you are using a stock type Manifold. Why try to pull a 14" runner past 75 or 8?
Old 10-26-2004, 10:38 PM
Stu'sWS6's Avatar
I am one of the crazies that is going to push the stock bottom end
Read my original post--I have rod bolts already.
Louis-I'm not planning on shifting the car past 7500-7600rpm, but I think that it will be pushing 8k going through the traps once it's figured out.
I thought that Thunder and Ed wright had figured out a way to get the stock pcm past 8k; I would love to be able go through the traps higher than 8000 once the new shortblock is in.
Old 10-26-2004, 10:58 PM
psykoTA's Avatar
Got video of that??
Old 10-27-2004, 12:06 AM
Casperws6's Avatar
he has the grand am cup cam and tuned the car himself using ls1 edit. I know it passed 8k for sure
Casperws6's Avatar
Originally Posted by psykoTa
Got video of that??
nope no video. he's actually a member on ls1tech.
Quick Reply: Who has revved their H/C 346 over 7500? With stock rods?
