cam only vs heads and cam
alot of the bigger cams these days like the tsp ms3 and trex are putting down more peak hp numbers than alot of heads and cam cars. i understand that with heads and cam the power will be in a more useable rpm range but what is going to be faster down the quarter mile a cam only set up making say 425 rwhp or a heads and cam set up making the same power? given the proper suspension, gearing, traction, etc. would there be much of a difference in ets?
LS1 Tech Administrator
If the rwhp is the same for each car and the gearing and suspension is optimized for each motor's unique power band, they will ET the same. This is purely a racing statement. From a street standpoint, the heads/cam vehicle will make lots more rwhp and torque in the 2,000-4000 rpm range than the cam only car and would most likely make its 425 rwhp at a lower rpm than the cam only car. This would make for a much more enjoyable ride.
Let me put it another way (hypothetically):
425 rwhp Heads/cam car would make peak power at 6000 rpm, peak torque at 4500 rpm.
425 rwhp Cam only car would make peak power at 6300 rpm, peak torque at 4800 rpm.
Heads cam car might make best ET with 4.30 gears.
Cam only car would make best ET with 4.56 gears.
ET should be the SAME! (just two different ways of approaching the same goal).
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
I can agree with what Patrick said, but also if you want to go with a head and cam package, I would think that the heads would hold up better. They would be built to run with the cam that you have, and they would hold up a lot better. With the LS1 we have shotty springs, and the pushrods would go for a change as well, thats why im going to go with the SLP head and cam package, and get the chromeoly pushrods while im at it since the heads will be off and i can just yank the others rods out of there. So that way you have the best of everything and you dont have to worry about anything breaking as easily. But the is just my OPINION.
Anyway, back on topic:
Can someone please explain to me why having better heads gives you power earlier? Thanks in advance
Well said, but anyone who makes 425 rwhp with cam-only will have upgraded springs, pushrods, retainers and locks to much higher quality pieces than OEM. The only difference between heads/cam and cam-only would be the more limited airflow of the stock heads. Stock GM heads, valves, and rockers are very robust. The springs, retainers and pushrods are weak links. Same for OEM timing chains and oil pumps. They suck. Cam-only applications making 425 rwhp will usually change these items as well.
__________________
More airflow means more power at the same rpm. Said another way, a head that flows 20-30 cfm (across the valve lift range) vs. stock heads will make over 20-30 rwhp at the same rpm. It's simple math. If you make 400 rwhp cam-only at 6000 rpm, you might make 425 rwhp with heads/cam at the same rpm. The heads/cam combo was already at 400 rwhp by 5700 rpm. It's packing in more air for every stroke of the piston, therefore it makes more power...period!
__________________
You usually see 20-25 more rwhp with a nice set of ported heads over stock with the same large cam setups ! I have not seen much over 450 RWHP with H/C and 425 with Cam only!
The main key when adding a cam it to get Headers to get the exhaust out more efficiently !
Thanks for clearing some things up guys
I see two big advantages of a H/C package over a cam only installation. First, you don't need an insanely big cam to make big power in an H/C car. Second, if you decide you want an insanely big cam at least while putting up with it you'll know you're getting your money's worth. With the cam only, you'll have the same issues to deal with while never realizing the cam's full potential.
Originally Posted by XTrooper
I see two big advantages of a H/C package over a cam only installation. First, you don't need an insanely big cam to make big power in an H/C car. Second, if you decide you want an insanely big cam at least while putting up with it you'll know you're getting your money's worth. With the cam only, you'll have the same issues to deal while never realizing the cam's full potential.
so say you have a car and all of your susp. is done you have a huge cam and make a bunch of power and go fast
now you take the same car throw a set of good heads on there and a tune you will make more power and go faster... no brainer
Tony
I don't remember what stock felt like anymore! lol Anyways, I think the H/C combo is obviously gonna give you more hp over a huge cam only car, and it will have a much better power range for the street.
Originally Posted by dug
Yeah me neither. It was weird, after installing the cam and headers, the car didnt feel that much faster. Now its starting to feel slow again.
LOL.. Im with ya.. RIGHT after my car dynoed the 397rwhp and I was starting to like the power it was making... I went for a ride in my friends turboed firehawk... ruined me.
LS1TECH Sponsor
If you have a big converter or launch high in a six speed then what a motor makes around 3000 rpms shouldnt matter. i made 401.6 cam only through an auto with a SY3500 converter. i have raced some heads cam cars with comparable power and It all boils down to the launch on who wins. Id say converter is the biggest player in Et's. i got beat by a friends car who made 388rwhp with a vig 3800.
