New FMS cam: FM14
Old 10-30-2004, 01:37 PM
FroDaddy's Avatar
Exclamation New FMS cam: FM14
I just saw this on their website. Specs are 232/234 .598/.598
Old 10-30-2004, 01:44 PM
cyphur's Avatar
Yep. Talked to Kip & Candy both about it a few weeks back. Should be a pretty wicked lil cam.
Old 10-30-2004, 01:47 PM
beardWS6's Avatar
What find of power do you think it will put out?
Old 10-30-2004, 01:51 PM
cyphur's Avatar
I think it'll top the -13 by ~10-15 peak. Not too much more. What you also have to realize is that FMS claims the powerband is 3k-7k, whereas the -13 is advertised as having a 2500-6800 band. So it doesn't peak too much higher, but you may lose some low end.
Old 10-30-2004, 01:54 PM
Scalpel's Avatar
FMS cams rock.
Old 10-30-2004, 05:13 PM
beardWS6's Avatar
I got alittle secret for you. MTI has a cam they are putting in mine right now as we speak that they have just made. First to put it in. Numbers will be in soon and its alot better than the X1 I just pulled out. I will let you know in about 10 days. The specs are sweet!!
Old 10-30-2004, 11:04 PM
CHRISPY's Avatar
What is the LSA and ICL of that 232/236 cam?
Old 10-30-2004, 11:33 PM
screamin00ss's Avatar
yea any fms cam rocks....good power at just about any rpm...cant wait till i get one
Old 10-31-2004, 01:13 AM
distortion_69's Avatar
FWIW: We got that cam a few weeks ago and just put it in a car. We will be at thunder running the car if all goes correctly. Possibly dynoing before then if time allows. I have a feeling its not going to make much less than the RJ, but will allow more options when it comes to heads, and be less peaky. Probably another 470-480rwhp cam in the right combo. One thing about Futral cams is they tend to make more power for the amount of duration used. So it will be interesting to see what numbers it will make. I imagine Allan spent some time designing this cam, because he never does anything halfass. So I would expect the same ol' FMS top notch performance
I'll try and let you guys know #'s if nobody else posts them shortly. The owner of the car is currently banned, unfortunately, otherwise he could post them himself
Peace,
Josh
Old 10-31-2004, 01:20 AM
cyphur's Avatar
Originally Posted by distortion_69
I have a feeling its not going to be be slightly less horsies than the RJ, but will allow more options when it comes to heads. Probably another 470+rwhp cam in the right combo.
Josh, would love to hear those results asap. Am very seriously considering this cam. How was the idle? Sound clips dammit!!
Old 10-31-2004, 02:54 AM
Still have yet to fire it up, doing rodbolts and spec stg 3 w/ billet steel flywheel. I'll be sure to get a video clip the moment its done.
Peace,
Josh
Old 10-31-2004, 04:01 AM
2MuchRiceMakesMeSick's Avatar
What are the specs on that cam?
Old 10-31-2004, 04:29 AM
BoneSS's Avatar
You all think it would clear some AFR'S w/o flycutting? That was my concern w/ the RJ cam.
Old 10-31-2004, 04:42 AM
PREDATOR-Z's Avatar
If it clears stock heads, it should clear AFR's. AFR has a little extra margin (~.015)
Old 10-31-2004, 09:25 AM
Mirek's Avatar
I have also seen Mamo post that the AFR's provide as little as .005 -.008 more clearance (which is still nice).
I am not sure which is true but I figured I would add that bit of info since it came up.
Old 10-31-2004, 12:12 PM
beardWS6's Avatar
2muchrice I will talk to david at mti and see when he wants to get the specs out. I will tell you this, its biggere than the F14 and where flycutting my pistons right now. I believe when we dyno tune her then they want the specs out-want numbers to go with it. One better is, I`m putting LSX90,90TB, Kooks 1 7/8 with it. Should be over 450rwhp with A4 easy!! As soon as everything is done I will put specs and results with dyno sheetout. Talk Soon!!! then I`mgoing to spray it
Old 10-31-2004, 01:20 PM
SidewayzOZ's Avatar
Peace,
Josh
If you guys dont get a chance for soundclips before this weekend we are bringing a video camera and a digital camera so we can get some good footage Did the clutch come in yet?
Old 10-31-2004, 02:06 PM
Nice sig.
Clutch came in last week. Along with the PCM.
Peace,
Josh
