should i flycut the intake and exhaust?
Old 11-01-2004, 01:16 AM
pdd
pdd's Avatar
Default should i flycut the intake and exhaust?
or just the intake? having my afr's milled to 60cc. this is with my fm11 cam and a .045 cometic head gasket
Old 11-01-2004, 05:36 PM
Beast96Z's Avatar
It's always best to measure. You might not have to cut either. You certainlly don't want to cut what you don't have to. It can effect the integrity of the piston to a minor extent and more importantlly, you don't want to lower your compression more than neccisary.
Old 11-01-2004, 06:28 PM
Viper's Avatar
pdd,
After reading of some of your issues the last few weeks, why not pay someone to professionally degree your cam and set the proper quench height? They can also measure for you and do the work to get the best out of your combination. You'll already have the heads off. For an extra couple of hundred, a local shop could port match your intake too while milling the heads.
Just a thought, my $.02.
Old 11-01-2004, 07:29 PM
pdd
pdd's Avatar
Originally Posted by Viper
pdd,
I have my quench figured out and i am having the heads milled and port matched by TEA. Besides all the work thats been done to my car besdies dyno tuning and head work, I did.
Old 11-01-2004, 07:37 PM
pdd
pdd's Avatar
thats why im having the heads milled to 60cc. with the flycuts adding 2 to 3cc ill be back around 11:1
Old 11-01-2004, 08:03 PM
Viper's Avatar
Cool, glad to hear you're getting the combo matched.
Old 11-01-2004, 08:34 PM
pdd
pdd's Avatar
im dyin too see what or if a diffence will be with the proper setup. crossing all the "i's" and "T's". any1 else with an opinion on the flycutting???
Old 11-01-2004, 09:28 PM
jpz06's Avatar
I don't know about anyone else, but when I'm spinning that Lg cam to 7k and I'm rowing through the gears the last thing I want on my mind is the thought of my valves slapping the pistons. It's not that big of a deal to cut them.
Old 11-01-2004, 10:59 PM
LS1Tech Sponsor
Slowhawk's Avatar
I wouldn't cut anything unless it is needed.These pistons are pretty thin to start with.The best thing to do is check the clearence first and go from there.Also make sure you use the right cutter/head to line the valve reliefs perfect with the valve's.
On another note don't forget to port match the intake and clean up all the flashing inside the runners
