Comp vs. Crane vs. Patriot vs. Precision vs. Rev
Old 11-01-2004, 02:14 PM
9 Second Club NA
Dragaholic's Avatar
Default Comp vs. Crane vs. Patriot vs. Precision vs. Rev
Comp dual valve spring kit-Roughly $560, .650" lift
Crane dual valve spring kit-Roughly $390, .650" lift
Patriot dual valve spring kit-$290, .650" lift
Precision dual valve spring kit-Roughly $290, .660" lift
Rev dual valve spring kit-Roughly $335 without valve stem seals, .650" lift
All have about the same rated lift and all have the same parts in the kit, but what makes them differ from one another besides price? Big difference between the Crank, Patriot, Precision, and Rev from Comp's kit. Comp's kit is the most expensive, but is it really worth the extra money? They all have the same parts in the kit and rated for the same lift, I dont see why there is difference in prices especially with the Comp. Im looking for a valvetrain kit for the T-Rex cam. What do you recommend? Thanks.
Old 11-01-2004, 02:56 PM
SidewayzOZ's Avatar
I would go with Thunder's recommendation. If you have a problem then at least they will back you on it. I'm fairly certain they still use Crane's.
Old 11-01-2004, 03:19 PM
eb02z06's Avatar
Don't forget Manley, they have a dual drop in from their Nextek line. After owning both sets of Cranes( old and new with stripes)I would not recomend them. Also the Cranes have the lowest open and closed pressures base on a 1.8 installed height.
Old 11-01-2004, 03:30 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
I have not read about any Patriot failures. The PRC's look good too.
Old 11-01-2004, 03:36 PM
luv2spd's Avatar
I don't think you can go wrong with either the patriot golds or the prc's. For the price and reliability, they're gonna be hard to beat!
Old 11-01-2004, 03:56 PM
smithsc's Avatar
I went with the Comp921's with the Trex in my 02 Z06.
Just figured the extra money got me alittle more security and durabilty.
Steve
Old 11-01-2004, 06:45 PM
MARKSZ71's Avatar
precesion race is what i would go with
Old 11-01-2004, 07:06 PM
9 Second Club NA
Dragaholic's Avatar
Well from what I know, Comp and Crane are well know valvetrain manufacturers that have been around a while. Rev, Patriot, and Precision Ive only heard of because of this site. Rev I believe was introduced first, then Patriot, and then lastly the Precision. The Patriots and Pecisions are the same price, yet the Precisions have .660" lift which is .010" more than the rest. Does anyone know why the Comps are almost double the Patriots and Precisions?
Vortech: Why dont you recommend the Cranes?
MARKSZ71: Why would you choose the Precisions over the Patriots? Theyre about the same price, yet the Precisions were just introduced here not too long ago?
Old 11-02-2004, 04:56 AM
z-ya's Avatar
Don't forget the patriots get you the super 7 lock set up, the others use stock.
Old 11-02-2004, 08:06 AM
Gunnar@Patriot's Avatar
Patriot .650" Gold Dual Spring Kit comes with The Orginal Patriot Gold Dual springs, ti retainers, super 7 locks, spring bases, and viton rubber seals.
All of this for only $279.50 !!
Old 11-02-2004, 08:31 AM
LS1Tech Sponsor
hellbents10's Avatar
I would go with the Patriot set-up myself. The cranes have lowest seat pressure open and closed, I think this is why they are not highly reccomended.
Old 11-02-2004, 09:21 AM
eb02z06's Avatar
Exactly! The Cranes have the lowest open and closed pressures. Depending on your cam, heads, valves u will need to shim so they work. With the other brands u can just drop them in as they are 140@1.8 while the cranes are only 112@1.8
Old 11-02-2004, 12:31 PM
Gary's Avatar
I went with the Cranes. They are not installed yet. I don't see a problem with shimming. It allowed them (Crane) to have the most flexible spring for different cam setups. Just because you have to shim them does not mean they are an inferior product.
Here is the response I got from Crane when I asked him about shimming:
Originally Posted by Mark Campbell from Crane
Sorry for the delayed response, but I was out of the state for a couple of days. There has been a good deal of misinformation about what shimming will and will not do. Shimming should not have a significant affect on valve spring life. It also doe not affect the harmonics of the spring but can affect the harmonic stimulation of the pushrod. It is necessary to provide adequate seat pressure to keep the valves from bouncing as they return to the seat. Fortunately, the LS1 valve train is relatively light and the large stock rocker ratio (1.7) multipies the seat pressure to help prevent bouncing of the lifter on the lobe. Our spring sets up at 112# at 1.800" installed height. We have purposely designed the spring with this seat pressure to allow shimming to the needs of the cam profile. We have kept the valve spring rate on the moderate side to keep the valve spring open loads from causing too much pushrod deflection at max lift. Too much open pressure will cause the pushrod to bend like a pole vaulters pole and cause an undesired "throwing of the valve" which means you have lost control of the valve train. Too much pressure and too high of a spring rate can cause just as many if not more problems than too light of a rate! (There are harmonic issues which are quite complex that relate to spring rate, lift rate of the lobe and rocker arm ratio that would take a text book to explain). If the seat pressure and spring rate are too high to start with, it's impossible to remove pressure!!. We also like the harmonics of this spring design over a wide range of applications. We feel our harmonics provide the best operation over the widest operating range of any spring on the market, and we have tested them all. I would recommend 120-125# of seat pressure for your application. A .030" shim should be the proper shim to place under the spring to achieve this seat pressure. This equates to a 1.765-1.770" installed height. With that seat pressure you should have no problems with valve train separation throughout your entire operating range (i.e. you will run into valve float problems from the inherent design characteristics of the lobe before you reach a critical harmonic in the spring!). Indiscriminately throwing valve spring shims under a spring is a sure way to disaster. We recommend measuring the istalled height of each valve spring and shimming as necessary to achieve the desired seat pressure. The seat pressure is the most important issue here and we have tried todesign a spring that provides maximum flexibility for maximum performance. We think we have succeeded. If you have any othe questions or issues, please feel free to contact me.
Old 11-02-2004, 01:03 PM
9 Second Club NA
Dragaholic's Avatar
What are the Super 7 locks?
GUNNAR@PATRIOT: When you say orginal Patriot Gold Dual Springs, is there another drop in dual spring that Patriot offers? Why did Texas Speed and Performance stop carrying this kit? The only sponsor that Ive run into so far that carries the Patriot kit is Speed Inc. and they sell the kit for $290. Where can I get it for $279.50 as you listed?
Do the Cranes come with shims? How will I know what shim to use?
Old 11-02-2004, 01:07 PM
eb02z06's Avatar
The Cranes don't come with shims. That's the whole thing-If i were to do it again I wouldn't use the Cranes. To use the cranes properly u have to get a crane installed height micrometer and a spring pressure tester to see what pressure the cranes will be at what installed height. All the other brands offer 140@1.8-u have to shim the Cranes to get that.
Old 11-02-2004, 01:12 PM
Cstraub's Avatar
Super 7 was a lock design of the late Randy Dorton. It is the only style of lock used in Nextel/Busch/Truck series engines due to its inherent design of not allowing the valve to drop if a spring breaks. Only difference since the cup teams run ti-valves with tips, their locks are taller and surround the tip to guard against it coming off.
Chris
Old 11-02-2004, 01:30 PM
Bo White's Avatar
I have heard of 1 or 2 super7 failures but never on the stock ones. I know that the Comp stuff is dead reliable but the price kills 'em. Also the patriots are doing well out in the field but the PRC looks nicer on fitment of all the parts. I think the Cranes got hurt in the pressure department because when you shim the spring what ever thickness of shim you use takes that much away from how much lift the spring can handle safely. Hope this is helful info.
Old 11-02-2004, 01:40 PM
Cstraub's Avatar
The super 7's did not fail. . ..something caused them to crack, and at that they did not drop the valve.
Doesn't matter whose spring you use, if the engine developments valvetrain harmonics the springs will fail. Period.
Chris
Old 11-02-2004, 02:00 PM
9 Second Club NA
Dragaholic's Avatar
Is Patriot the only company that offers the Super 7 locks? How come none of the other dual kits mentioned in this thread dont offer these locks? When you say locks, are you referring to the "keepers"?
Bo White: Why do you say the Precision kit looks better than the Patriot? Have you used/seen both kits in person? On most things, looks dont matter, but in this case, does looks make a difference? Reason why I brought that up is because you said the Precision kit looks nicer.
Old 11-02-2004, 02:03 PM
Cstraub's Avatar
Cost. . .OEM locks/keepers are 20X's cheaper then machined locks.
Chris
