compression ratio
Old 11-07-2004, 11:53 AM
Greg Fell's Avatar
Default compression ratio
Does anyone know how much compression milling ls6 heads .035 would add?
I computed and came up with 11.9:1, but this was using unmilled heads.
4.1 bore
4.0 stroke
4 cc valve reliefs (i think, there are some reliefs, biggen than an eyebrow size)
ls6 heads
6.125 rods
fwiw the cam is a 110 (+2) lsa.
Old 11-07-2004, 12:34 PM
Reboot's Avatar
Assuming a stock .thickness .054 head gasket with pistons .007 out of the hole. Milled (.035) LS6 heads apprx. 59cc chambers.
I'm coming up with 12.82
