What size valves are you using with your 427
I need to know what size valves you are using in your heads. 2.02/1.60, 2.055/1.6. I don't want to use 2.08/1.60 as new seats will have to be installed. I was thinking of 2.055/1.6 valves. That brings me to my next question: What size cams are you running with this motors. Thanks
I've got 2.055 1.60 valves on an iron 422ci. They work ok, but a bigger valve would probably work better. I did 490 something torque with an unlocked converter. Cam is a lunati 242 .595 112 lsa with 4 degrees advance (single pattern). Crazy low rpm power, and speedo picks up about as quick as the tach.
Originally Posted by Brian Tooley
2.10/1.60, if you can afford a 427 then $160 for seats should be no problem.
