Valve Lifter Preload Adjustment
Old 11-13-2004, 01:47 PM
Silver02's Avatar
Default Valve Lifter Preload Adjustment
Does anyone know the procedure for adjusting the valve lifter preload?
Old 11-13-2004, 05:58 PM
narcszm's Avatar
you adjust the preload value by shimming the rocker or going with shorter pushrods. You can check your pre-load by following the procedure about .667 into this article:
http://www.ls1howto.com/index.php?ar...a17dd1495959e6
