ok got my afr's back from TEA,
Old 11-15-2004, 11:28 AM
pdd
pdd's Avatar
Default ok got my afr's back from TEA,
here are the flow numbers
.1000 68.8
.2000 146.8
.3000 205.5
.4000 251.9
.5000 292.5
.5500 307.9
.6000 316.9
Old 11-15-2004, 11:39 AM
1fastWS6's Avatar
Nice #'s. You going with a bigger cam now to take advantage of the increased flow? What'd those cost too btw? $3k+?
Old 11-15-2004, 11:40 AM
gomer's Avatar
what was the before numbers? I'd like to see how much gain there was on them. Also, how much did you decide to mill them?
Old 11-15-2004, 11:46 AM
pdd
pdd's Avatar
.1000 68.8
.2000 146.8
.3000 205.5
.4000 251.9
.5000 292.5
.5500 307.9
.6000 316.9
before numbers quoted by AFR. i never had them flowed myself
.200 142
.300 202
.400 246
.500 280
.550 292
.600 300
staying with the same cam for now. i had them milled .024
Old 11-15-2004, 12:22 PM
7 Second Club
Phil99vette's Avatar
What all did TEA do to the heads? What did the combustion chambers end up at?
Phil
Old 11-15-2004, 12:47 PM
Dumb Ass Vette Moderator
ls1290's Avatar
My TEA Stage III 6.0L heads flow better than those AFRs. What was done to them?
Keith
Old 11-15-2004, 12:50 PM
pdd
pdd's Avatar
Phil
i had them ported polished and milled. there at 62cc. phil your mailbox is full
Old 11-15-2004, 12:54 PM
pdd
pdd's Avatar
Keith
they ought too with a 4.0 + inch bore. mines a 3.9 bore
Old 11-15-2004, 12:57 PM
gomer's Avatar
Do you know what the intake runners and exhaust runners ended up cc'ing at when finished?
Old 11-15-2004, 01:04 PM
7 Second Club
Keith
Keith,
You can't really compare flow numbers but if you have the same bench it somewhat levels the playing field. The main question is what does your cylinder head flow vs port size? A 180cc port that flows 300cfm will make more power than a 250cc port that flows 300cfm.
Phil
Old 11-15-2004, 01:44 PM
Reboot's Avatar
Great numbers! Can you post up the exhaust numbers that TEA quoted. I just got mine from TEA on Friday with the standard exhaust port. My intake flow numbers are very similar to yours.
225CC runner 2.055/1.57 valves
.100 71 60
.200 142 127
.300 208 189
.400 260 236
.500 296 257
.550 306 261
.600 315 266
Good luck with your setup
Old 11-15-2004, 03:11 PM
pdd
pdd's Avatar
here is the exhaust flow
.1000 59.5
.2000 124.1
.3000 184.1
.4000 227.7
.5000 252.3
.5500 263.4
.6000 268.2
Old 11-15-2004, 04:43 PM
SideStep's Avatar
.1000 59.5
.2000 124.1
.3000 184.1
.4000 227.7
.5000 252.3
.5500 263.4
.6000 268.2
Sweet when is all this coming together????
Old 11-15-2004, 05:07 PM
pdd
pdd's Avatar
sooner the better
Old 11-15-2004, 06:23 PM
Beast96Z's Avatar
The intake port TEA uses on there 2.5 is around 228 cc's. Some people don't realize that they use the same port for there LS-6, 6.0, and AFR heads. The Stage 3's flow the best. The reason these AFR's have lower numbers than the 6.0 /3's is because they are the same ports as the 3's, shrunk .030" for the 2.05 valve. These are refered to as the 2.5's, which are intended for 3.900 bores. The 3's are for 4.00"+ bores. I got my AFR 2.5's about a week and a half ago. I've been spending alot of my time port matching my LSX, but I think I've about got it.
Old 11-15-2004, 06:51 PM
JaSSon's Avatar
My TEA 1.5s flowed 306@.600 on the intake and 267@.600 on the exhaust. Killer heads for $1400.
Old 11-15-2004, 07:16 PM
pdd
pdd's Avatar
great info beast. i had TEA port match my 90mm fast intake
Old 11-15-2004, 09:29 PM
jrp
SN95 Director
jrp's Avatar
i'd like to see some independent numbers...
Old 11-15-2004, 11:59 PM
WS-Sick's Avatar
I hope you get your setup where you want it this time. Good luck!
Old 11-16-2004, 06:46 AM
m1key99WS6's Avatar
My AFR 205's out of the box flowed 306CFM @ .600 (28in water) on a superflow bench locally. These heads make soo much torque!
