Will I clear the pistons with this cam?
Old 11-15-2004, 11:15 PM
Timberwolf's Avatar
Default Will I clear the pistons with this cam?
238/244 .610" / .615" lift (lift given with 1.7 ratio rockers) on a 112lsa
Stock pistons and valve size...
Old 11-15-2004, 11:18 PM
LSUxBlake's Avatar
It'll be close, I'd mock it up before i said for sure.
Old 11-16-2004, 12:05 AM
MachoCamacho's Avatar
So would a 240/240 .608/.608 112 cam clear heads? or even better 240/240 .608/.608 111?
Old 11-16-2004, 12:53 AM
LSUxBlake's Avatar
Like I said, the only way to know for sure is to mock it up. One reason is because unless you've had it cam doctored and know the specs are exact, there is a relatively high potential for a slight misgrind which could go in the direction you don't want it to. From those 2 cams, the 112 would have a better chance of clearing, but who knows.
Old 11-16-2004, 06:33 AM
DAPSUPRSLO's Avatar
Depends on what the intake centerline is. If they are on a 108 icl then you will have no problems comparing them to the TREX.
