Crane 1.8 Rocker question
Old 11-18-2004, 01:11 PM
Batman WS-6's Avatar
Default Crane 1.8 Rocker question
What is the valve lash supposed to be on the Crane gold 1.8 Rockers for an LS1???
Old 11-18-2004, 07:18 PM
KJ
KJ's Avatar
Very nice rocker arm set. I installed them on the 408 in our Tahoe. I don't know to be exact, but there is a series in how they want you to adjust them. It explains it very well in the directions. If you do not have them give me a call and I will get Crane to fax them to you.
Old 11-18-2004, 09:52 PM
mrr23's Avatar
first i'll assume you are using a hydraulic cam. as per VHP, the people that helped in designing the rockers with Crane, you want about .060-.120 preload on the lifters. how far down the lifter plunger is pushed down into the lifter. there is zero 'lash' on a hydraulic cam. lash term is used on solid lifter cams. where you have an amount of gap between the rocker and valve tip.
Old 11-20-2004, 06:39 AM
XTrooper's Avatar
Instructions call for zero lash.
