View Poll Results: WHICH HEADS ARE BETTER
5.3 HEADS
4
50.00%
241 CASTING
4
50.00%
Multiple Choice Poll. Voters: 8. You may not vote on this poll
Which Heads Are Better 5.3 Or 241 Castings?
I Have A 228/234 607/598 @110 Cam And Slp Long Tubes/ Ory Pipe With Borla Cat Back Which Heads Would I Benefit Most From
the 5.3 will up the CR but one of the vavles is smaller than the ls1.
If you are just going to slap on stock 5.3 or 5.7 then i would not even wast you time doing a swap. If you are going to get ported heads then it does not matter what casting they are they all flow the same if ported the same(853-241).
SN95 Director
