Need Cam Doctor specs for TR 236 and FM 13
Originally Posted by Damian
Tr= 236/230 ???/??? ???
Fm13= 230/232 .595/.588 112
Originally Posted by jrp
chances are your not going to get that info w/o buying the cam and doctoring it yourself.
Originally Posted by DramaFoYoMama
237/230.5/599/575 112.1*
I repeat.... FULL SPECS PLEASE!!! As in Int/Exh durations for a full spectrum of lifts....
Ie: My cam specs!
Sorry, not trying to be peeved but I thought i was being pretty explicit. I can look up .050 values anywhere... that much should be obvious... A good comparison has nothing to do with spec values a moment's lift... Thank you for trying to help though
interesting comparison vs my cam ,duration @ .050 is 238/236 112lsa. FMS doesnt send out doctored spec's. heres an FM14 cam card though if you'd like to look at it.
Thanks Jerami... it's something to start with... I guess if anyone else has doctored an FM or TR cam please lemme see! Thanks
Thunder's cams are doctored in house, but you only get the normal duration/lift specs on the box. I didn't have a chance to get the full report on my TR236 -- just the specs from Thunder which were posted earlier.
