T-rex on a stock 02' SS????
Old 12-02-2004, 12:33 AM
MuTiLaToR's Avatar
Default T-rex on a stock 02' SS????
hi all, I am thinkin about going with TR's Trex cam for my SS. Its a 2002 bone stock. I will be ordering Long Tubes, true duals, Lid, filter, and pro 5.0 shifter along with it. but i have a few questions. is it possible for me to use the stock 3.42 gears?? i have a 6-speed. also, do i need the dual valve springs???
i have a completely stock longblock and I hope someone can help me out w/ this. Hopefully with a good tune i can use this as my daily driver as it is right now. thanks in advance for any help
Old 12-02-2004, 12:41 AM
cyphur's Avatar
**** yes you need dual valvesprings. otherwise kiss your motor goodbye
sounds like a bunch of mods at once. the t-rex is a huge cam, i've ridden in a car with one. go for it, but i'd also up your gears a bit....3.90 at least. trex cars CAN be used as DD's, but remember, valvesprings get worn out by big cams like this. it helps you have an m6.
personally, i'd do all those mods you are thinking about, and drive it around for a little while. THEN do the cam install. you might be suprised how well these cars react to mods...and how much power can be tweaked out of them.
Old 12-02-2004, 01:18 AM
35th SS's Avatar
I second that.a must you will need dual vlv. springs. for this cam.do all the bolt ons as much as you can.raise your rev limiter to 7200rpm and let er ripped.good luck.
Old 12-02-2004, 02:28 AM
Danoldo's Avatar
the fact that he just said 7200 RPM is insane. I'd limit yourself to 7000 RPM on a stock bottom end.
Also, the TRex is a VERY VERY big cam, and altho it CAN be daily driven, my OWN opinion would be to not daily drive that cam.
If you want a "big cam" with great daily driving, i'd highly suggest the G5X3 from LG Motorsports. I run it, and about 10 other guys in my club who are daily drivers run it as well. Dual valve springs are a must with this cam, I suggest COMP 921's, only becaues they are the best.
Btw, going with a any "big" cam, you need LS1 Edit to tune it and get it running right (or HP Tuners/mailorder/etc). Lastly, knowing big cams, I would HAVE to suggest at least an LS6 intake. With a big cam that likes to breath up top, you need it. I had my LS1 manifold on the X3 and as soon as it hit 6100RPM's, the power would drop off so fast it was crazy. As soon as I installed teh LS6 manifold, it would hit 7000RPM without a blink!
Good luck!
Old 12-02-2004, 03:19 AM
35th SS's Avatar
exactly what you said.not a daily drive car here.track only.
Old 12-02-2004, 03:56 AM
MuTiLaToR's Avatar
am i going to have to have the heads messed with in order for the springs to fit?? also i still want to know if running the stock 3.42 gears in the m6 is possible with this cam, b/c i do not have the money for a 12 bolt. with a good Ls1 edit tune and rev limiter set to 7000, i do not see why this cannot be a Daily driver. Also, how much of a difference are we talking between the t-rex and g5x3???
Old 12-02-2004, 09:41 AM
cyphur's Avatar
like i said in my first post.....bump your gears to at least 3.90. it will make life easier. you CAN get away with stock gears, but it won't be pretty. most dual valvesprings fit w/o machining the heads. ie comp 921's, patriot gold duals, prc duals. they all work well. the cam CAN be a daily driver, its just going to be a PITA thats all. its a big cam and is going to act like one. the trex is bigger than the g5x3.
Old 12-02-2004, 10:02 AM
luv2spd's Avatar
Personally, I sure wouldn't go that big on a daily driver cam. You'll go through springs very fast and with stock gears it will feel like a slug down low.
Old 12-02-2004, 11:40 AM
technical's Avatar
Good luck!
I thought '02 fbody's came with a LS6 manifold?
Old 12-02-2004, 11:49 AM
Tranzor's Avatar
There's no way I'd drive a car with a cam that big with stock 3.42s... it would take forever to get into the powerband. I'd step up to at least some 4.10s if not 4.30s.
If you don't get the proper support parts for that kind of power, you're going to wonder why your car isn't as fast as you think it should be with a cam that large. There's a lot more to going fast than shoving a cam, slapping some bolt-ons to it and mashing the gas pedal. Things like a 12 bolt rear end, steep gears, better clutch, better suspension pieces, and stickier tires are all essential when you're pushing that kind of hp through your car.
Old 12-02-2004, 12:57 PM
MuTiLaToR's Avatar
would i be able to use the g5x3 w/ the 3.42's??? b/c like i said b4 i dont have the $$ for a 12 bolt just yet, and i'd like to maintain the stock gearing. as long as the cam isnt going to cause me to stall out around town I have no problem with it feeling sluggish down low. at the track i launch at around 35-3800 which is where the trex starts making power, and more than likely it will see most of its action on the track so i dont see why it cant be daily driven. as long as i get the comp 921's i don't understand why i would go through springs very fast???
Old 12-02-2004, 01:16 PM
technical's Avatar
>.600 lift and agressive lobes for starters. In the old days that was considered a "race only" cam.
Old 12-02-2004, 04:30 PM
Possible Scammer - Buyer Beware - Issues Unresolved
00ls1's Avatar
stick the 4.10 in there till you can get a 12 bolt, you won't regret it. you might wanna check into ARP rod bolts too...
Old 12-02-2004, 04:34 PM
MuTiLaToR's Avatar
so ur saying for me to put the 4.10's in the 10 bolt??? i've heard really bad things about lowering the gear in those rears...
Old 12-02-2004, 05:02 PM
rufretic's Avatar
I don't think your 10 bolt will last very long launching at those rpms with the Trex or any other large cam for that matter. Unless you have no traction and your tires just spin, and then whats the point. I'd look into preparing your car a little better before throwing in a huge cam.
Old 12-02-2004, 05:08 PM
Cefiro's Avatar
Dont even think about racing on the street with this cam, and you will def. need a new rear end. Most people who get this cam build the motor and go larger displacement. This is a race only cam for a reason. If this is your first cam I would get a small one, and then move up as needed.
Im sure you like the sound of 500rwhp, but 400rwhp is no sloch either.
Spend a couple days searching, and learning about the timing and lift of a cam. Also, a good idea is to call a sponsor and tell them your goals and let them help you pick out a cam for your needs. I dont know anyone who uses a T-Rex in a daily driver.
Old 12-02-2004, 05:14 PM
cyphur's Avatar
I'll be real honest with you man. It sounds like you wanted to come on here and be reassured you weren't doing anything wrong with putitng in the t-rex in, and now that you're hearing stuff you don't like, you're arguing with us. people have tried it, and this is the knowledge that has been collectively learned by the board and its members over time speaking out. why are you tryin to argue with us? you asked, we answered.
you WILL NOT get the results that other people are getting from this cam, unless you are setup properly for it. yes, you can scrape by and "survive" with it in the car, but whats the point. 2MuchRiceMakesMeSick runs a trex as a daily driver and his car is very managable. he's also running a moser 9" rear, dennys n2o driveshaft, a FAST 90mm intake setup, full bolt ons, Lanes true duals, mickey thompson 28" rears....his car is setup to HAUL ***.
if you just want to scrape by, go right ahead. however you'll end up breakin ****, and it will cost you far more in the long run. do it right the first time. it sounds like your car needs some more prep before the t-rex, but thats my personal opinion. good luck either way.
Old 12-02-2004, 07:23 PM
formulaforlife's Avatar
You might want to invest in some HARDENED PUSH RODS!!!!!!
That cam likes rpms in the 6650-6900 range so a light valvetrain would be a wise choice as well.
Old 12-02-2004, 07:47 PM
2MuchRiceMakesMeSick's Avatar
I have this cam in my daily driver.
Get the cam package from thunder for this cam (dual springs only). This cam will be hard to manage untill you get full boltons and a great tune. Any boltons that you do (such as gears) will make this cam alot better.
Old 12-02-2004, 11:09 PM
screamin00ss's Avatar
500? whered that come from...thats an awful lot for a cam only car, has someone just accomplished this feat? if they have then i apologize
