LS-1 Heads 853 vs 241 castings
I have a 2000 WS-6 M6 with a TR224 cam, LS6 intake, Hooker LT's,Offroad Y-pipe, Borla Cat Back, G2 Airlid, Ported TB, Spohn LCA's, Spec Stage 1 w/aluminum Flywheel, Stock 10 bolt 3:42's, Comp Cam Springs, Pushrods, and Retainers, Heads are stock 853's.
Dyno numbers are 368rwhp 347rwtq Figured would be higher across the board.
Dont have the money to buy new heads but wondering if I bought a set of 241 casting heads $200.00 and had them CNC ported would I have a better result than having the 853's ported?
Would consider Patriot heads but have heard good and bad things about them.
SN95 Director
once ported the differences through the different castings are minimal.
are you basing your PP info on the old problems? i've yet to hear any new ones since they've undergone some changes. if your worried about valves you can upgrade to ferrea or manley's for 100 bucks.
but before you drop money on heads i'd find out your current problem. are you tuned, what was the AFR, ect.
About 7 months ago the car has started dying at startup (surging) even when car is warm. If I have the A/C on you can forget it. Is it common for a car to start having this problem? There is no SES light. Run a scan and every now and then it has a knock sensor code.
Kind of a newbie what do you mean by AFR?
Originally Posted by SpankysWS6
I have the money to get the car Tuned if I put Stock ported Heads. I bought the car a little over a year ago and What I have done to it is Clutch and Flywheel and LCA's. Bought the car with all the other mods. I have reciepts from AMS showing that the car was tuned on August 2002 when the other mods were installed. Only thing that was changed after the tune that I didnt do was the Ported TB.
I am from Fort Worth, Texas. I have heard there are some good shops around here.. MTI is about 3 hours away. Lg Motorsports is about and 1 hour. I will contact one of them and meetup and talk about what the issue is. Thanks for the info. Been a Great Help..
My goal is 420+ on a H/C stock 346 bottom..
forgive my ignorance...but what is the difference between the two casting heads?? theyre both 5.7l LS1 heads correct....and i know the perimeter bolt heads were 806's i believe?? Just wondering, didnt mean to highjack the thread
SN95 Director
Adding to jrp is that the 241s are die cast and the 853s are sand cast. The reason the 241s flow better stock for stock is the die casting leaves a smoother surface compared to the older sand casting method. Definately a tuning deal, that cam should handle idleing and a/c use with ease.
