Solid motor mount plate, shaving water pump
Old 12-05-2004, 03:33 PM
Boostaholic's Avatar
Default Solid motor mount plate, shaving water pump
Is it ok to shave the water pump when using a solid motor mount plate?
I would have to take off .0260IN to make it line up with the crank pully
Old 12-05-2004, 07:10 PM
NLang's Avatar
There's plenty of meat on them for a .026" low-spot. That's not much material removed.
Old 12-05-2004, 07:41 PM
I'm sorry, its supposed to say .26 not .026
Old 12-05-2004, 11:51 PM
NLang's Avatar
I personally wouldn't go .26" in unless you were cutting even deeper and reinforcing the thin wall (or hole) with weld. It may be possible w/o reinforcement, but I wouldn't take the chance. Being a pressurized system, you would run the chance of bursting there. That's if .26 wouldn't go right through, which it just may...I'd suggest clearancing the mount.
Quick Reply: Solid motor mount plate, shaving water pump
