Budget 382 Stroker ?
How much roughly am I looking at to get one built?
I have no clue in this subject because I thought this would be something I'd do next year or even further down the line. But since my bottom end decided to fail me this past weekend this is now something I'm considering.
Re: Budget 382 Stroker ?
Pete are you planning to do the motor yourself? Some of the sponsors have good deals on the kits.You'll need the Block honed.Save some money assembling yourself..If you just want the short block MTI had some good deal..
LS1Tech Co-Founder
Perhaps you can get the rotating assembly for ~$3500, it comes already balanced you would just need to machine the black. You will need a new cam too since your C2 will be too small and it's mostly ruined.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Pro Stock John:
<strong> Perhaps you can get the rotating assembly for ~$3500, it comes already balanced you would just need to machine the black. You will need a new cam too since your C2 will be too small and it's mostly ruined. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">John, is that through MTI?
Their special now is $5K for a complete shortblock plus $800 core charge.
LS1Tech Co-Founder
Yeah, I was just talking about the rotating assembly. The Lunati (3.905 bore x 4.000 stroke) kit comes with a billet crankshaft, pistons, billet rods, and some other little stuff. The crank is like $2500 of that cost.
<strong> Yeah, I was just talking about the rotating assembly. The Lunati (3.905 bore x 4.000 stroke) kit comes with a billet crankshaft, pistons, billet rods, and some other little stuff. The crank is like $2500 of that cost. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Ya, I got that part, was asking if the rotating assembly is also through MTI.
I'm also gonna inquire locally at AES.
wounder what the cost of a 382 all bore set up would be, new pistons, rods all forged and stock crank, could later be upgraded to a 422, hmm ever think about that route
JET
JET
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by JET:
<strong> wounder what the cost of a 382 all bore set up would be, new pistons, rods all forged and stock crank, could later be upgraded to a 422, hmm ever think about that route
JET </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Sounds nice but wouldnt I need an iron or resleeved block?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by I8COBRA:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by JET:
JET </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Sounds nice but wouldnt I need an iron or resleeved block? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Not to be off topic or anything, but what happened to your motor? I remember just a couple weeks ago you did heads/cam at Speed Inc. right?
To be on topic - if you did an all bore, I think you can do that without going to an iron block or a resleeve. JPR's 382 allbore is with an aluminum block. Then all you'd need to upgrade would be the crank and rods later to get a 422.
<small>[ April 15, 2003, 05:28 PM: Message edited by: JF WS6 ]</small>
Yeah, the heads/cam was done in January. I had about 500-600 miles on it and went roadracing this past weekend. Engine went BOOM!! <img border="0" alt="[bomb]" title="" src="graemlins/gr_bomb.gif" /> <img border="0" alt="[bomb]" title="" src="graemlins/gr_bomb.gif" /> <img border="0" alt="[bomb]" title="" src="graemlins/gr_bomb.gif" />
Bad <img border="0" title="" alt="[Frown]" src="gr_sad.gif" /> I'm almost in your same boat, with the budget rebuild. Mine is consuming massive amounts of oil, I'm looking to go JPR more than likely, I was told recently that he phased out of 382's and is building 387's now (through e-mail) Correct me if i'm wrong. My only problem will be tuning, as I am in nawf carolina and I can't seem to find a tuner anywhere. Good luck!
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Andy
Andy
You could go All bore, like said, but the Compression Height is going to change with the new crank and rods.
CH for stock crank and 6.125 rods: ~1.311
CH for 4" crank and 6.125 rods: ~1 .130
Keep the rods, and get a new crank and pistons <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
BTW- Were you at Road America?
I too am thinking of this very hard. what about the SCAT crank? how much is that and is it a good piece? do the bearings have to be replaced or is it just a good idea?
Drew
Drew
I8COBRA:
Dude, i can't believe your motor grenaded while road racing. THAT really SUCKS and i feel for you man. What gave, a rod bolt, a dropped valve?
Anyways, keep your head up man. ON the bright side it looks like you will end up getting more power faster than you anticipated. Best of luck to you on getting back on the road as soon as possible.
MTI 427 Roadster
MTI 427 Roadster
<strong> Rod bolt most likely.
Not sure yet what the next plan will be. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Man I feel your pain. I blew my motor on Sat. I am waiting to get the results, but the prognosis isn't good. I ran out of f-ing gas going down the track about mid way. I am an azzhole. Car was running strong, then I go and do this. Joe Prince(JPR) built my motor on the TOP HALF, and he seems to think MAYBE a rod bolt let go on me as well. He never touched the bottom half, but right now I am wishing I had more money then and I would have had him dig his hands around there too. I am SCREWED right now. No $ + No Engine= very sad man right now.
<img border="0" title="" alt="[Frown]" src="gr_sad.gif" /> If 2 people are a GP, we should talk. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> Good Luck. May God Have Mercy On Their Souls. The car went 11.70 115 at 3720 RW. Obviously their was VERY little gas in the car so it was EXTRA light that day. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
To Our fallen LS1's <img border="0" alt="[USA]" title="" src="graemlins/patriot.gif" />
<small>[ April 21, 2003, 07:55 PM: Message edited by: Bear ]</small>
