AFR Heads and Yella Terras
Old 12-09-2004, 08:43 AM
VortechC5's Avatar
Default AFR Heads and Yella Terras
Just a heads up...
If you are going to be using Yella Terra rockers with AFR heads you will need to clearance the back of the rocker slightly for clearance. Mine actually cleared but it was only by about .010 to .020. Yella Terra calls for .060 minimum clearance.
Not a big deal but it is something worth planning for.
Old 12-09-2004, 12:49 PM
DanZ28's Avatar
Pretty sure Yella Terra's on my ported OE heads only have about .010-.020" clearance, definately not .060". Anyone else?
Dan
