pushrod question??
Old 12-12-2004, 02:30 PM
BTLFEDSS's Avatar
Default pushrod question for hot cam swap
i am doing a cam swap witha hot cam and comp 918 springs.My question is can i run the stock pushrods with this set up.I'm going to retain stock rev limiter so would this be ok
Thanx BTLFEDSS
Old 12-12-2004, 04:22 PM
66deuce's Avatar
i would go with the hardened pushrods,even with the stock rev limit.
Old 12-12-2004, 05:14 PM
BTLFEDSS's Avatar
ToTheTop
Old 12-12-2004, 05:16 PM
BTLFEDSS's Avatar
Anyone with hot cams chime in here
Old 12-12-2004, 05:24 PM
68birdls1's Avatar
i plan on getting the hardened push rods as soon as i get the money! but for now i have the stockers
Old 12-12-2004, 05:42 PM
I8RICE's Avatar
I would drop the $110 for hardened pushrods. I bent 3 rods on a stock motor. with a rev limiter of 6300. It'll give ya peace of mind. Not having to worry about the stock pushrods.
~Rob
Old 12-12-2004, 08:18 PM
BTLFEDSS's Avatar
Thanks for the replies guys
Old 12-12-2004, 08:35 PM
luv2spd's Avatar
Yeah, its worth the money. The stockers will flex at the higher rpm which won't give you true vavletrain geometry.
