Texas speed, PRC Valve springs
Old 12-13-2004, 08:45 PM
dvandentop's Avatar
Default Texas speed, PRC Valve springs
so how are these things. have a friend interested in getting a TSP kit deciding to go with either these or the 918 kit
i have patriot gold duals and have worked great.
Old 12-13-2004, 08:55 PM
CamaroCain's Avatar
what are the cam specs?
Old 12-13-2004, 08:58 PM
dvandentop's Avatar
i am sure it will be something simliar to mine in my sig
Old 12-13-2004, 09:13 PM
TVWilkes's Avatar
The PRC kit will work perfect for all hydraulic roller cams.They will hold up to .660 lift.
Old 12-13-2004, 09:14 PM
jrp
SN95 Director
jrp's Avatar
what are the full spec's of the PRC's: open and seat presure, o.d/i.d, and install height? and how do they differ from the PP gold?
Old 12-13-2004, 10:43 PM
TVWilkes's Avatar
Here are the full specs of the PRC spring kit.
seat : 140lbs
open: 390lbs
install : 1.800
coil bind: 1.07
1.290 O.D.
max lift : .660
matl : super pure chrome silicone
They differ because the PRC kit has more open/closed pressure and a different valve rate.
PRC has many new parts that will be released soon.
Old 12-13-2004, 10:49 PM
jrp
SN95 Director
jrp's Avatar
looks close to the PP's
(jason)
Doubles Good to ATLEAST .650 lift
Coil Bind Is At .720 lift...
Springs are Super Pure Chrome Silicone Vanadium
They're Electro polished to help spring life & remove spring impurities
They're 1.29” diameter so the heads require no extra machining!
Pressures:
140#@ Seat
390# Open
(terry)
135lbs @ 1.800
385lbs open
coil bind @ 1.08
whats the valve rate on the PRC's?
Old 12-14-2004, 03:57 PM
01PewterWS6's Avatar
I just put in a TSP 231/237 .595 .598 cam this weekend with the PRC springs. So far its alive
Sounds awesome and pulls like a SOB!
Old 12-14-2004, 05:47 PM
MUSTANGEATER's Avatar
(jason)
Pressures:
140#@ Seat
390# Open
(terry)
135lbs @ 1.800
385lbs open
coil bind @ 1.08
Aren't the springs in question made by the same company?
Old 12-14-2004, 08:02 PM
jrp
SN95 Director
jrp's Avatar
:dunno:, thats why im probing for info. im just wondering if there is any legit reason to buy the PRC's over the PP's when the PP's are almost spec for spec the same and come in at a lower price. im curious the spring rate to compare to my PP's.
Old 12-15-2004, 01:28 AM
Associated spring makes them I think. I'll call them and see, but first I need to find their phone number lol.
Old 12-15-2004, 01:29 AM
dvandentop's Avatar
interesting i will keep an eye out on this
Old 12-15-2004, 04:52 AM
TVWilkes's Avatar
PRC has not released the manufacturer of their spring.
Old 12-15-2004, 09:49 AM
Gunnar@Patriot's Avatar
Not only is our Patriot Gold kit more economical, it comes with more. Our kit comes with springs, ti retainers, viton rubber seals, machined bases, and New Super 7 Locks. Some kits only come with stock locks or no locks at all....just use your old, used locks. Why pay more for less?
BTW, who is PRC? Who owns the company? Where are they located? What is their phone number? What is their web or email address? Did anyone see their booth at the PRI show?
Old 12-15-2004, 10:02 AM
Cobraeater's Avatar
Talking
That's true, never seen anyone from PRC on the board anyway.
Originally Posted by EDC
The AFR valve springs are coming from the same source as PP and PRC (and a lot of other places) purchase them from.
No magic here, "Associated Spring" makes them for everyone.
I've been buying the same springs in bulk for a while now.
Good pieces no matter what color!
Ed
Old 12-15-2004, 10:26 AM
Gunnar you forgot to mention the "Gold finish" costs a lil extra even though its just cosmetic.
Old 12-15-2004, 12:20 PM
AdamSS's Avatar
I tried to "google" PRC (Precision Race Components) but found nothing.
I'm with Gunnar on that one. I don't think PRC are worth more than PP.
Besides, before I buy anything I tend to research the product: Who makes it, reliability, cost, etc. When RaceTech tells me that it's "secret and was never released" then usualy it means that they hide something.... Sorry, difference between .650 and .660 valve spring advertised lift is minimal. (and I'm sure that's PRC's advertising catch anyway) I'll take a proven and less expensive kit from PP.....
Old 12-15-2004, 01:08 PM
TVWilkes's Avatar
There is many well known companies that do not set up a booth at PRI.Setting up a booth doesn't give a company an automatic stamp that the product they sell is worthy,and better than others.PRC is handled by the proven companies that sell their products.If you need information call a retailer.
Old 12-15-2004, 01:29 PM
2000PewterZ28's Avatar
If the super 7 setup from Patriot is so good,why didn't AFR use it when they were buying the gold spring?AFR no longer uses this spring.I have friends that have broken the super 7 locks.There also have been folks on the board who have broken them.If you want something that is proven and never failed,its the GM lock.
Old 12-15-2004, 01:37 PM
Cobraeater's Avatar
Question
You're a retailer for PRC, so why don't you give us their phone number and address.
You would think they would want the business, or is it supposed to be a secret?
Quick Reply: Texas speed, PRC Valve springs
