Timing Gear and Chain Questions...
Old 12-14-2004, 04:34 PM
Byter's Avatar
Default Timing Gear and Chain Questions...
Hi Guys,
1. Has anyone installed a cam and found that the cam guide pin is bigger than the guide hole for the top timing gear? If so, how did you remedy the situation?
2. I bought the Rollmaster non-adjustable single with timing chain. Is it ok to use the new top gear and chain, but use the old bottom crank gear (it looks good and I don't have a tool to insert the new one)?
Thanks, Tony
Old 12-14-2004, 07:14 PM
Byter's Avatar
Any suggestions? Drill hole bigger in timing gear?
