Correct Push Rods?
Correct Push Rods?
I have a 98 LS1 that I am putting a LS6 cam and springs in, what are the correct pushrods? I have been told that when using the LS6 cam with the LS1 heads that the push rods have to be 0.05" longer then stock. Does any one have a part number for some aftermarket push rods?
Thanks
Thanks
I have also been looking at GM's Hot Cam, what would you recomend Hot Cam or the LS6 Cam? Still running the stock converter but have 3.73 rear gears. I forgot to mention that the engine is all stock, except I am not running cats and have 2.5" dual exhaust.
