Which Lifters For Trex Cam
I am getting ready to do a cam swap and I need to know what the best choice of lifters would be for this cam.
I was going to just stick with stock ones cause I have not heard anything bad, but have decided would be a little risky with the agresivness of this cam.
So what Should I be looking for.
I have Stock rocker arms.
7.400 hardned pushrods
Dual patriot performance Springs
A stocker would be fine but, with the high rpm that the cam is designed for I would use a Comp Pro Mag (R series) part 875-16 You have stock rockers, so I would use a stock lifters because of preload that the R's require.
!LS1 11 Second Club
Originally Posted by sevanseriesta
Thank you so much for your replies......What kind of power gains did you guys get. I am trying to get low 11's with just the cam.....Think It is possible
Originally Posted by SMOKIN01TA
trust me low 11's is definalty possible. my times in sig, trex cam stock heads,
use stock lifters or stock replacement lifters not roller lifters
Crane lifters are garbage. I had 2 of them pump up.
Ive been running the stock lifters ever since. with my T-rex.
about 300 passes since going back to the stockers. most of them in the 10.2-4 spray, and 11.3 motor range and no problems.
With any lifters.
There are 2 kinds of rockers.
Adjustable
Non-adjustable (like stock)
1- On adjustable rockers you set the preload after 0 lash on the p-rods with another 1/2 to 3/4 turn (depends on manufacturer's recomendations)
2- On non adjustables 2 ways,
a> custom length pushrods
b> shimming the rocker stands
Adjustable
So am I going to have to pre load anything with my 7.400 pushrods and stock rockers.
Also is there anyone that can tell me what might be ticking in my engine. I was racing someone and I shifted from 3rd to 2nd at 6000 rpms. clutch grabbed and rear locked. Now my engine ticks after this. I am not sure where it is comimg from exactly but It sounds like it is coming from under the car more then anything.
I already run ET streets now I am just trying to find a good price for a Torque Arm that is not transmission mounted
PM me if you have any questions.
