Who makes a good oil pump
Old 12-19-2004, 08:38 AM
8 SEC SLOPPY SHOT!!!
tuff's Avatar
Default Who makes a good oil pump
Just as above. And what is the diffrence between the stock pump and the modified pumps or are they aftermarket.
Old 12-19-2004, 08:50 AM
PREDATOR-Z's Avatar
They are LS6 ported.
Old 12-19-2004, 10:16 AM
Bill Bowling's Avatar
Talking
I just bought a LS6 Ported Oil pump from Texas Speed. i am planing on replaceing when I install my TSP Torquer Cam.
Bill
Old 12-19-2004, 12:09 PM
PREDATOR-Z's Avatar
Bill
Do you know that 01/02 have LS6 pump to begin with?
Old 12-19-2004, 12:54 PM
cyphur's Avatar
Porting them shouldn't be too horribly difficult, most sponser's pumps are also shimmed for higher pressure.
Old 12-19-2004, 04:25 PM
Camaro99SS's Avatar
I'm at a loss. What's wrong with stock LS1 oil pumps (except some of the faulty 98's)? At WOT I get 70psi when on a hot motor. LT1's and SBC's on the other hand, are lucky to get anything over 50psi on stock pressure springs.
Jason
Old 12-19-2004, 04:30 PM
LS1SS4ever's Avatar
Wink
This what I would say it
Old 12-19-2004, 06:33 PM
tuff's Avatar
Jason
So it might not even be worth changing my oil pump
Old 12-19-2004, 06:38 PM
Crazy Man's Avatar
Texas speed has a good one. Or Scoggin Dickey has a good one also. I wouldnt go into my engine just to change the oil pump unless its bad but if your changing cam or something you might as well.
Old 12-19-2004, 07:21 PM
tuff's Avatar
My motor is out and when my motor was built about 3 years ago no one really wasnt doing much with pumps.
Old 12-19-2004, 07:24 PM
DrkPhx's Avatar
With your good oil pressure, I would leave it alone.
Old 12-19-2004, 07:44 PM
Z-286speed's Avatar
I am running into the same thing, i want to install a cam, but dont want to be set back 120 bucks. So, would 72,000 miles be too much?
Old 12-19-2004, 10:06 PM
Mike454SS's Avatar
I'm curious about the pump from the LH6...the displacement on demand engine. It's suppossed to be a higher volume pump...shouldn't that help feed oil to a turbo?
Old 12-19-2004, 10:10 PM
Quick Time's Avatar
We just cam out with our 2 piece timing cover and high volume oil pump. Its not a portd oem piece. Brand new cast pump. 10 more psi and 15% more volume. Call me if you have any questions.
Old 12-19-2004, 10:11 PM
Crazy Man's Avatar
If your oil pressures fine then dont worry about it just keep a eye on it. But it is alot easier to do it when doing the cam.
Old 12-19-2004, 10:19 PM
C_Williams's Avatar
Here's a link to the DOD pump. They claim more volume.
LS2 Hi Volume Pump on EBAY
Old 12-19-2004, 11:10 PM
cyphur's Avatar
$215 for an oil pump? I don't think so. I'll buy an LS2 oil pump and port it myself before I spend that much money. **** thats expensive.
Old 12-20-2004, 01:15 AM
Mike454SS's Avatar
Is the LS2 pump the same as the DOD 5.3 pump (LH6 I believe)? I also would buy it from GM...
Old 12-20-2004, 01:30 AM
Hot02SS's Avatar
Look at the SLP pumps.
Old 12-20-2004, 03:48 AM
Blktie8's Avatar
I had a 2000 and for the price of the pump I put in the katech The Jwis chain and rod bolts also from Katech
