Fly Cutting - Why, How, How Much, & Alternatives?
Old 12-21-2004, 01:57 PM
SOM_of_a_Beach's Avatar
Default Fly Cutting - Why, How, How Much, & Alternatives?
Currently in my car:
160 T-stat
SFC’s welded in
Aluminum Lower Control Arm’s
Pro5.0 shifter
Lou's short stick
3.73 gears
Front sway bar removed
Whisper lid
K &N Filter
Borla Catback Exhaust
What I have in my living room:
AJE K member
AJE A arms
5.3 Liter Heads (stage 1.5 done by TEA)
Comp Cam (232/240 @ 114 LSA)
Weiand intake (hand ported by TEA)
Weld Drag Lites
Direct port pro fogger race kit (NOS/Holley)
Bottle warmer, Purge kit, Blow Down Tube, etc.
Holley Blue Fuel pump
Kooks stainless steel headers
Battery Relocation Kit
BMR Battery Relocation Kit
(I am gonna sell my borla to get the money for x pipe and true duals)
Okay sooooooooooooo, I was told my piston need ot be fly cut. Can some one tell me why I have to do this? I would like to understand the technical portion. Also, one person qouted me 12 hours of labor for fly cutting, is this correct? I am thinking if different pistons will run me the same as the fly utting then why should I even bother. Please help me understand.
Ive seen the pictures of fly cutting and have read that if it is too thin than it wont handle nitrous etc etc. Any information is appreciated. Also feel free to post up links that I could refer to.
Thanks,
Crystal
Old 12-21-2004, 02:57 PM
please help me understand, or post links to more informaiton so I can educate myself. thanx
Old 12-21-2004, 03:27 PM
94form2000z's Avatar
The reason you'd have to would be to keep the piston from hitting the valve as if that's not obvious. Depends on the specs of your cam and whether or not you milled the heads at all.
Old 12-21-2004, 03:31 PM
pdd
pdd's Avatar
do a search bro. i just flycut my pistons last week and have a few pics of it on a thread here
Old 12-21-2004, 03:45 PM
I did a search, read the first 3 pages worth and didnt really snawer my question. I understand the obvious..to prevent a piston from whacking into something. But what makes it necessary is it the type of heads I purchased or the cam that makes fly cutting necessary? How long does it typically take and are there any alternative (i.e. purchase of another piston if the price is equivalent to that of the fly cutting)
Thanks,
Crystal
Old 12-21-2004, 04:07 PM
racer88's Avatar
Crystal, the amount of lift you have from the cam. Cam specs could be ie; .608 .613 in the intake and exhaust. Too much lift on milled heads becomes a clearance issue as the above guy mentioned of pistons whacking the valve. That's why on some pistons they are dished to allow for the lift when it comes to valve clearance. Without cutting yours it's evident there isn't enough clearance with the lift of the cam he picked out for you.
It's techincal stuff, I would really look into forged racing pistons that will work with your set up. You are going to eventually need that with higher compression especially with nitrous.
Old 12-21-2004, 05:34 PM
pdd
pdd's Avatar
I flycut my pistons in about 2 hours. when you mill your heads that brings them closer to the pistons. so by cutting the pistons this allows more room between the piston and the valves
Old 12-21-2004, 05:48 PM
2MuchRiceMakesMeSick's Avatar
I considered it but then I though, why spend money on something thats going to break. When mine goes ill go forged and buy them notched.
Old 12-21-2004, 06:52 PM
pdd
pdd's Avatar
[QUOTE=2MuchRiceMakesMeSick] why spend money on something thats going to break. QUOTE]
why would they break? unless your spraying huge nitrous shots at them
Old 12-21-2004, 07:19 PM
BLASTER's Avatar
I think flycutting would be cheaper to do than replacing all your pistons.
So if you understand the reason that you flycut is to avoid hitting the valves with the pistons, what is unclear?
Your cam duration, advance, LSA, CC and valve size dictates you P to V clearence. Your combo incorporateds 5.3 heads which have small CC to raise compression which means that the valves will be closer to the piston and since your cam is of moderate size, your P/V clearence will be compromised.
Old 12-21-2004, 07:58 PM
Dustin 98TA's Avatar
Its not necessarily the lift alone that will make P/V issues. Its a combination of lift and duration. With a low duration and high lift, you could probably get by, when you raise the duration the valve stays open longer and the piston could possibly hit it.
The only sure fire way to tell is to clay it and see what you got.
Old 12-21-2004, 09:13 PM
NLang's Avatar
Lift isn't at all a determining factor. It's how long the valves are held at a certain lift (duration) as well as a valve timing that causes the interferance. Generally, 8* before (intake valve) and 8* after (exhaust valve) the piston reaches top dead center is where the valves will be closest to the piston tops.
Old 12-21-2004, 09:23 PM
Squintz Palladoris's Avatar
FYI Piston to valve cearance can be checked without claying the pistons. You can get some weak springs specifically designed for checking clearances and valetrain geometry. Once you figure out if you need to fly cut (and if so how much extra clearance you will need) you put the proper valvesprings back on.
Brad
Old 12-21-2004, 10:44 PM
Beast96Z's Avatar
#1 dictates your camshaft spinning in the motor. When it turns it lifts....
#2 your lifters/pushrod, which presses your
#3 rocker arms
#4 the pressure from that presses your spring/valves open
#5 is the piston. It's coming up while the valve is open. If it is open to long,(dictated by the size of your camshaft), it will hit the piston. This is where you would need
#6 a valve relief or fly cut. (dictated by the orange mark on the piston. By cutting into the piston, you make a place for your valve to go instead of it smashing into it.
Due to the angle of the valves to the pistons, diffrent size valves will bring you closer or further away to the piston. So, if your heads are milled, your bringing your valves closer to the pistons, if your valves are bigger, your bringing them closer to the piston, and if you install a larger camshaft, you are holding the valve open longer and pushing the valve down further, so it has more of a chance to hit the piston.
Did that help any?
Old 12-21-2004, 11:04 PM
pdd
pdd's Avatar
great pic and defanition beast
Old 12-21-2004, 11:18 PM
Beast96Z's Avatar
I was bored and wanted to try my hand in the paint shop.
Old 12-22-2004, 12:02 AM
That was the best reply I have seen on this site man. Next to Try a search on this subject lol.
Good stuff man you really must have been bored!
Brad
Old 12-22-2004, 07:48 AM
#3 rocker arms
Did that help any?
Thank you very much, that was actually very helpful. BTW, the lift is .595/.608
Have you guys ever heard of diamond pistons? I was told they would make a direct fit and are inexpensive.
Thanks,
Crystal
Old 12-22-2004, 09:01 AM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Crystal, just do yourself a HUGE favor and get a cam that's a bit smaller. The TSP 233/239 or a FM13 or FM14 on that setup will kick ***.
You can pick up the 233/239 from Texas Speed for $310 right now.
Do this and there should be no need for flycutting.
Old 12-22-2004, 12:05 PM
Beast96Z's Avatar
If your heads aren't rediculously milled, then you shouldn't have a problem anyway. Do you have any more specs like cam advance(usaully a+1,2,3,4 after the LSA number on the cam, the actual LSA, and how much if any, the heads were milled?
Quick Reply: Fly Cutting - Why, How, How Much, & Alternatives?
