Dry sump with internal pump?
Old 12-23-2004, 10:01 AM
Boostaholic's Avatar
Default Dry sump with internal pump?
I've seen info posted on this before, but I can't seem to locate it.
Anyway, I was thinking about dry sump systems, and for a street car, it does not seem like a bad idea to use the normal internal pump with a external sump and evac pump to the sump.
Can anyone give me some feedback or info on this?
Old 12-23-2004, 10:27 AM
Cstraub's Avatar
A dry sump does not have an internal pump. It has to be exernal. The purpose of a dry sump is to keep the oil reserve out of the engine for better oil control and more power. A dry sump will be standard in 07.
Chris
Old 12-23-2004, 12:21 PM
y2khawk's Avatar
Gary Armstrong's pan can be set up to use the existing interal oil pump as the pressure stage, www.drysump.com
Still uses an external tank, and requires a 2 to 3 stage scavenge only external pump.
Old 12-23-2004, 02:45 PM
8 Sec Tuner
Mike TexaSS's Avatar
You can also use a dry sump pump as an external wet sump pump and a vacume pump all in one. Use the pressure stage of the pump as the wet sump pump and use a scavange stage for the vacume pump.
Old 12-23-2004, 05:02 PM
Thats what I was looking for.
