Torquer cam on stock tune?
Old 12-25-2004, 12:42 AM
LSONE's Avatar
Default Torquer cam on stock tune?
how's this bad boy gonna handle on a stock tune? it might be a few weeks before i have enough money to get her tuned, and i REALLY dont wanna wait to install it. anyone have any experiance? I've heard mail in tunes arent nearly as good as a shop tune, so should i opt for one?
Old 12-25-2004, 01:01 AM
Possible Scammer - Buyer Beware - Issues Unresolved
00ls1's Avatar
im sure a mail order tune wouldn't be too bad if you got it from TSP since they developed the cam and know how to tune your car accordingly
Old 12-25-2004, 03:44 AM
Silverhawk_02TA's Avatar
I'd hold off and get a tune by a good shop or someone local with HPT that knows his stuff. I ran my Torquer on stock tune for about two weeks. It was beastly at times, but it got me around. Like any big cam, hot starts are going to be a bitch, and it's going to hunt for idle and stall out at times in neutral, especially at low speeds. The key to getting the Torquer to run on stock tuning, like any other big cam, is adjusting the TB set screw to let in more air at idle. Without this, my car was not drivable, as it would die almost every time I put it in neutral and didn't keep the gas pedal pushed in a little. With adjusting the set screw, I got it to the point that it would still hunt for idle, but almost never stall out. Good luck!
Old 12-25-2004, 06:15 AM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
TSP is sending out mail order tunes for $250 with the purchase of their cam. Not bad!
Old 12-25-2004, 08:39 AM
PREDATOR-Z's Avatar
IMO, to change a cam without tuning should never be done. (especialy big cams)
You'll hurt the motor (over rich or worse too lean).
The problem is that a lot of us are so impatient to get more power, that we sometimes forget that it has to be done right.
Old 12-26-2004, 01:54 PM
matty169's Avatar
Default Jasons mail order tune WORKS excellent. TSP tune.
Installed 232/232, .595 lift,113+2 in a 1998 a4 WS6 with stock converter and the car was undriveable, almost. Sent computer to Jason, got it back in 2 days, and I'm in Wisconsin. Car started instantly, found idle, and ran great. Shifting was also vastly improved. I'm sure a custom tune would possibly be better but know one around here does them. Just my .02.
Old 12-26-2004, 01:59 PM
LSONE's Avatar
well, i have rev xtreme about 30 mins away and they are a very good shop, so i dont wanna spend 200 on a tune then get another one from them. can jason customize the tune, like delete rear o2's, air, etc? and tune it for the mods you have?
Old 12-26-2004, 02:46 PM
jrp
SN95 Director
jrp's Avatar
bingo. and dont ask me how i know
Old 12-27-2004, 02:38 PM
matty169's Avatar
Default Yes, Jason can.
You send him a list of what your set-up is and he programs whatever is necessary. Mine is o2 delete,TQ management delete,fan temp changed,ETC. Basically the same as a custom tune, only without the dyno or AFR. Mine works awesome.Also A.I.R and EGR delete.
