crank pulley bolt wont come off
Old 12-26-2004, 02:40 PM
SSPerformance's Avatar
Default crank pulley bolt wont come off
i had my good 1/2 air gun from work i was raping on it preety good and cant break it loose.... Is it reverse threaded by any chance
Old 12-26-2004, 02:44 PM
jrp
SN95 Director
jrp's Avatar
is the crank locked? either 4th gear (m6) or lock the flex plate (a4). and all you need is a 24mm socket and a long breaker bar, it really not that hard.
Old 12-26-2004, 02:53 PM
how whould i go about locking the flex plate
Old 12-26-2004, 02:59 PM
jrp
SN95 Director
jrp's Avatar
your in the middle of a swap and you dont know that , you sure you want to tackle this?
anyway, you'll need a flex plate locking tool or a big ******* screwdriver. you'll need to drop the starter or remove that circular plate thats on the tranny or tranny cooler.
Old 12-26-2004, 03:24 PM
ight just checken i new what it ment just not shure where because of the full bellhousing setup
Old 12-26-2004, 04:58 PM
99ssleeper's Avatar
If it is an auto you need to drop the starter and you'll be able to hold the flexplate in there...big ******* screwdriver is right. It is a bitch.
Also, tightening it is a bitch too. It is regular thread, not reverse.
Good luck!
Old 12-26-2004, 05:12 PM
ight thats what i thoguht.....i thought i could get away with the impact gun.....
Old 12-26-2004, 05:17 PM
Viper's Avatar
I did, and the engine was out. I had to hold the BF screwdriver in, then use the electric impact gun. Came right off.
Old 12-26-2004, 06:34 PM
TT-TECH Veteran
Inspector12's Avatar
I always use an impact and never have had any issues getting it off. Only twice have I had to use a long breaker bar. Hd some one hold the flywheel with a screwdriver on the bellhousing access hole. Good luck!
Old 12-26-2004, 09:02 PM
35th SS's Avatar
everyone has different route of doing this.I used the flexplate locking tool like jrp mentioned.more safe and easy.had to borrow from a friend shop.good luck.
Old 12-27-2004, 04:01 PM
AINT SKEERED's Avatar
A good impact and just let it work for a little while. build some more pressure and work again, it will come off.
Old 12-27-2004, 05:46 PM
IMD
IMD's Avatar
f its cold where you are, try putting some heat on the bolt.
Old 12-27-2004, 08:37 PM
LS1Tech Sponsor
Slowhawk's Avatar
I use an good impact gun with 160psi of air pressure and never had a problem.Try ussing a torch to heat the bolt area,then it should come out easilly.(make sure you have a new front seal)
Old 12-28-2004, 12:08 AM
BadAndy's Avatar
I used a 24" breaker bar, which I destroyed. Thanks a lot Great Neck, you suck . Autozone gave me a new one and it got the job done. If the engine is turning before the bolt breaks loose, it may be losing compression. Are the spark plugs still in place? If the motor isn't turning over, then your impact gun is a weak little bitch. Yeah, that's right. You tell him I said that.
Old 12-29-2004, 09:19 PM
fastbasser's Avatar
The flywheel locking tool is about $50 from GM. Just drop the starter and bolt it in its place. Works like a dream. Its gonna be just as much fun putting the balancer back on.
Right tools make things easier....
JMHO
Old 12-29-2004, 09:31 PM
68birdls1's Avatar
i had no problems, but my motor was on a stand and my buddy had a big ole' screw driver, didnt even have to use a 24" breaker, got off with a 12" but after that g-pa told me he had a 24" wish i would have known earlier, that **** was hard lol
