7.350 pushrods
7.350 pushrods
i have 7.400 hardened pushrods. my heads are milled .024. i checked preload and i needed shims. i put .065 washers on and got preload were i wanted it(thanks beast96). i have HS rockers also. as i turned the engine over the rockers hit the vavle covers. so i ordered 7.350's. now i have a fm14 cam. so do you guys think 7.350 pushrods will be ok?
Ya 7.350 should be just right if you had to use .065 washers. With the shorter pushrods you should be right where you need to be. You are hitting on 00 heads? That is odd they usually have plenty of clearance even with some shim usually a max of .035
Hope it works OK for you.
Nate
Nate
