P to V clearance question: AFR 205s and 224/228 .581 114
Originally Posted by SPANKY LS1
If I were to use set of 205 AFRs (66cc) and a 224/228 .581 114lsa camshaft, how much could I mill and be safe as far as P to V clearance, assuming a GM MLS gasket? .020? .030?
Thanks, Shawn
Thanks, Shawn
Measure twice, cut once...
Here is my crude math, and taking into account the following quote:
Ok, MLS gasket is ~.054 thick IIRC. So, using the above car as a guide, I would have ~.015 more P to V clearance just from the gasket thickness difference, which would put me at ~.109/.140 clearance assuming the heads are milled .024. So, hypotecially, if I were to go .030 or .040 even, I would still have plenty of clearance. [Disclaimer: I know I can't judge my setup working based on anothers measurements, but it is a rough guesstimate]
Shawn
Originally Posted by Tony Mamo @ AFR
The AFR 205 head will provide you with an ADDITIONAL .010-.015 piston to valve clearance when compared to a stock 65-66 cc chamber LS6 casting. Assuming you mill either the 205 or a factory LS6 casting to the same "lower" figure for additional compression, you will always have slightly more piston to valve with the AFR 205. Regards, Tony Mamo AFR Sales / Product Design
Shawn
