Question about AFR heads and non-AFR valve springs (PP, PRC, Comp)
Old 12-31-2004, 05:46 PM
SPANKY LS1's Avatar
Default Question about AFR heads and non-AFR valve springs (PP, PRC, Comp)
On AFRs website, it says the spring pocket is 1.450" O.D., but the spring is only 1.290” O.D. It uses a spring cup (like the Comps, Patriot, and PRCs do I believe). My question is this, can I simply replace the AFR springs with one of the "kits" from PRC or Comp and be good? Do the other kits (Patriot, Comp, PRC, etc) also have a cup that "centers" the spring in the larger opening?
Thanks, Shawn
Old 12-31-2004, 06:17 PM
Beast96Z's Avatar
If I'm not mistaken, the AFR's come with the Patriot springs. I believe that is who they contracted to provide them with springs. Hence the 1.290 OD. To answer the other question, yes, the other kits do come with a centering spring cup on the bottom.
Old 12-31-2004, 06:51 PM
kickassT/A's Avatar
yes, afr uses patriot springs
Old 01-01-2005, 12:24 AM
SPANKY LS1's Avatar
Why are they only rated to .600 lift? Aren't PP duals rated to .650?
Old 01-01-2005, 12:33 AM
TVWilkes's Avatar
AFR does not use the Patriot spring anymore.At the PRI show they had their own spring.To answer the question,YES,you can replace the AFR package with the PRC,Comp, etc....
Old 01-01-2005, 12:35 AM
SPANKY LS1's Avatar
Thank you.
Shawn
