Upgrading my cam? Big difference?
Old 01-01-2005, 10:42 AM
01Z0H6's Avatar
Default Upgrading my cam? Big difference?
Stepping up from a TR220/220 .563 .563 112+4
to a Comp XER 228/228 .588 .588 114......
This is on a full bolt on car, A4 3500 stall 323 gears...
Check my sig..... Let me know what you think.
Thanks.
Old 01-01-2005, 10:57 AM
98Raptor's Avatar
I think will will probably only pic up about 10rwhp or so. If you are going bigger I would go bigger.
Why the change?
I do have a good cam for sale if you are interested. 232/236 .595/.601 on 114+4 LSA
Old 01-01-2005, 11:49 AM
TT-TECH Veteran
Inspector12's Avatar
That looks like the off the self Comp grind except the +4.
Old 01-01-2005, 12:06 PM
98Raptor's Avatar
It's the RPM4 custom grind. On a 98 TA with just bolt ons and LS1 intake. The car picked up 45rwhp and 25 rwtq. The car also had a bad tranny.
Old 01-02-2005, 12:12 AM
01Z0H6's Avatar
I am "considering" stepping up.
My car is driven daily & a buddy of mine was going to give me a pretty good deal. 10 HP?
I don't think it's quite worth the trouble.
I may go ahead and buy it & hold on to it til i do the LS6 Stage 2 heads.
Surely that would net me some power......
thanks, for the replies.
Old 01-02-2005, 05:32 AM
SLP/Drew's Avatar
thanks, for the replies.[/QUOTE]
from what i have learned recently is increased compression doesnt add as much as you would think it would. What more compression gives you is the abillity to put a bigger more aggresive cam in. So i think what they are trying to say is if you step up, step up to even a bigger cam then what your looking at
-hope that helps
Old 01-02-2005, 09:54 AM
01Z0H6's Avatar
I guess the 228 is not considered very big anymore huh?
As i said. My car is driven daily.
Don't want to lose the daily drivability. You know?
Thanks again.
