AFR 225 small chambers (62cc)
I was told end of January, so you may want to try this again in a month.
Ben
Ben
Originally Posted by SlickVert
AFR 225 small chambers (62cc) where are they?
Tony, how about an update please.
Insomniak,
62cc heads, should put the compression around 11.1
Mill them to 58cc with a 2cc valve relief (fly cut pistons for larger cam) should put it at 11.3
Looking forward to these heads!
thanks.. thats what i'm wanting.. 11.1:1 so i can still run pump gas..
hope these know heads can crack the 500rwhp mark w/ a g5x3 cam.
actually i'd be happy w/ 450rwhp lol i've seen as high as 485rwhp out of the 205cc heads
The tech @ AFR I talked to said it was a different setup altogether and NOT a milled version.
Originally Posted by DrkPhx
I thought the 62cc heads will just be milled and not a different casting.
