tsp 231/237 with comp 918's
Old 01-04-2005, 02:37 AM
2000bluess's Avatar
Default tsp 231/237 with comp 918's
I am about to get the tsp 231/237 and I was wondering if I is really that safe to run it with the comp 918's? I was doing some searches and it seems like some people on the board run them and havent had a problem with it. But others say to just get the PRC's from texas speed or the patriot dual's. I know it would be smarter to just go with the dual's and be safer, but is it really possible to be able to run it with the comp 918's?
Old 01-04-2005, 04:02 AM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
It's possible. I only ran it wih 918's 'cause the 918's were already installed from a smaller cam setup. But, if you're gonna do it from scratch, get the duals.
Old 01-04-2005, 04:21 AM
greekss's Avatar
im tellin him to get this.... 222 224 .566 .568 112º
wouldnt he make decent power with this ?
Old 01-04-2005, 04:25 AM
!LS1 11 Second Club
Why would he want that?
And, with the new TSP 233/239 or the 233/233, why would he want the 231/237 unless he already has it purchased?
Old 01-04-2005, 05:14 AM
greekss's Avatar
what would u recomend for 918 sprigs then, cuz that is what he will be using ?
Old 01-04-2005, 06:06 AM
AINT SKEERED's Avatar
I just installed the fm13 and am using 918's . NO problem, these are good springs.
Old 01-04-2005, 06:17 AM
!LS1 11 Second Club
If you must limit your cam choice to a set of springs you already have (and have not yet installed), that's working *** backward. If he must run the 918 springs, then the TSP 231/237 is a fine cam for the 918's due to its lazy ramp rates.
The FM13 has more aggressive lobes.
Old 01-04-2005, 06:27 AM
FRCBobby's Avatar
I think someone from TSP stated the the 233/239 would work with the 918's. I could be wrong on that though.
Old 01-04-2005, 06:29 AM
!LS1 11 Second Club
I read that also. I'm not going to question that, but I personally wouldn't run that setup.
Old 01-04-2005, 11:11 AM
LS1Tech Sponsor
hellbents10's Avatar
No matter what you are running a risk the dual offers a little more safty. I would run the 918's on a 233/239. Remeber this though I am not one to be afriad, i can tear out the motor on a days notice and put parts in it and go agian. I would say go for it if as you are set on the 918's. Just remeber don't over-rev and check them every so often.
Old 01-04-2005, 12:10 PM
cyphur's Avatar
Ain't that the truth. You choose springs for a given cam, not a cam for a given set of springs. Do you have them installed already?
Old 01-04-2005, 12:21 PM
PREDATOR-Z's Avatar
.581 lifts XE-R lobes here. 918's, shifting at 6600. (7000+miles)
Old 01-04-2005, 02:54 PM
2000bluess's Avatar
No I havent installed them already nor do I have a set of 918's I was just wondering if it was safe to run, or if I should just go with the dual's.
black_ws6's Avatar
I hope so considering I just had a 231/237 cam and 918's installed Saturday.
Old 01-04-2005, 02:58 PM
!LS1 11 Second Club
Safe to run TSP231/237 with 918's? Yes. I've done it.
Should you go with the duals over the 918's? Yes.
Old 01-04-2005, 03:15 PM
Jon@Texas-Speed's Avatar
918's will work fine with this cam. I'm currently running it and have even sprayed a pretty large shot. If you are wondering what one to purchase for the cam, I would run the PRC Spring kit just to have the safety of the dual spring. Also, with the PRC's you have the choice of running a larger cam down the road without having to replace the springs again. However, either spring will work fine for this setup though.
Jon
TSP
Old 01-04-2005, 04:41 PM
black_ws6's Avatar
Jon
TSP
Thanks Jon!
Old 01-05-2005, 07:38 AM
2000bluess's Avatar
Jon
TSP
Thanks
Old 01-05-2005, 10:13 AM
1972chevelle454's Avatar
Man if u get the 231 looks like im going to need the 233.......there no way i could let u have a faster car than me, i must be bigger than you, thats all i care about ahhhhhhhhhhhh
-bofevens
Old 01-05-2005, 01:38 PM
2000bluess's Avatar
-bofevens
Do it, ill still be faster then both you bofevens. You should go to Sears Point and take the driving school
