What can I rev to NOW?
Old 01-10-2005, 12:45 PM
jermzz's Avatar
Default What can I rev to NOW?
I'm switching from my TR224 / 918's to TSP 233/239 and PP Gold duals.
Be here in about a week...
I was reving to 6600 with the 918's, what can I do now? I'll have to see the dyno sheet to know for sure what I can rev too power wise, but what about mechanically without worrying about float.
I have s2 heads, manly valves blah blah put down about 395 ish on the old setup with no ls6 intake.
Old 01-10-2005, 01:18 PM
Tranzor's Avatar
My rev limiter is set at 7k rpms with my 231/237 cam... I shift around 6700-6800 rpms since the cam seems to peak around 6200, give or a take a little. I'm gonna guess that your cam will be similar in where it peaks, maybe a tiny bit higher... I wouldn't want my engine to live at where my shift points are at on the stock bottom end, but I'm confortable with it on the occasional trip to the drag strip.
Old 01-10-2005, 01:33 PM
jermzz's Avatar
Thanks for the opinion
You ran a 12.2 with that cam and a 12 bolt? I would expect better!... did something happen? (no offence ofcourse if it was a good run) I just would think the times would be better. With my 224 no 12 bolt and no intake or LTs I was running 12.7
Old 01-10-2005, 02:46 PM
greekss's Avatar
what was our 60 foot jeremy when u hit the 12.7 ?
Old 01-10-2005, 02:56 PM
Tranzor's Avatar
No offense taken... a 12 bolt actually won't help you go faster, it'll just help to make sure you don't break as easily.
I ran a 12.6 full bolt-ons with no cam installed at all, and on a 10 bolt with 4.10 gears. Adding just the cam and the 12 bolt (which actually adds more weight, so it doesn't help) with the same exact gear ratio that I had in my 10 bolt dropped my times by over 4 tenths of a second.
The reasons for ET and trap speed being what they are:
1) stock clutch... couldn't launch at anything over 4k on the stocker, which bogs the engine at the line when using ET Streets... to really get a great launch and great ET, I really needed to launch at around 5500-6000 rpms, and the clutch literally wouldn't do it. I have a DVD of my runs that day, and you can also hear the clutch slipping badly on every upshift (RPMs hang big time), which also slowed me down.
2) I didn't powershift... I used to lift my foot from the accelerator on each upshift because I didn't want to trash my tranny. I'm having the transmission built up this off-season so I can powershift it this coming season and not have to worry about it breaking on me... no more lifting if I can at all help it.
3) I live in Seattle, and our air isn't great compared to a lot of places when talking about racing... the conditions are horrible by any means (we're not Denver or anything) but it certainly could be better.
4) I still have some room for improvement as a driver, I ain't gonna lie about that.
I'm confident with launching at high rpms and with powershifting this car has the potential to easily drop into the high 11s, as long as I drive it well enough. High 11s is pretty much all I would expect from this car N/A on stock heads.
Old 01-10-2005, 03:30 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
6900 limiter on my setup. H/C combo peaks at 6400.
Old 01-10-2005, 04:02 PM
Caribe's Avatar
I also got the TSP 233/239 with the PRC kit, so I emailed Jason at TSP and this is what he told me."It will peak about 6200-6300 so I would shift at 6500-6600" and the rev limiter between 6700-6900.
Old 01-10-2005, 06:53 PM
Kurtomac's Avatar
just remember your valve springs arent usually the limiting factor in deciding how high you can rev.....its the rod bolts that usually take a **** from high revving
01-02 got better rod bolts IF yours is a 01-02 i would feel more comfortable with 6800-7000 although with 7000 you are living on the edge.....if you have a 98-00 i wouldnt go higher that 6800 although some do and live for a while to tell about it just look at a dyno graph see where it peaks and choose a limiter based upon that, go a few hundred RPMS higher than peak power for example i peak at 6400 and limiter is 6800 i could use another 1-200 rpms but i dont want to replace my short block anytime soon,
hope i helped
Old 01-10-2005, 08:36 PM
LS1_PNYTAMR's Avatar
okay so about 6500 wouldl be decent on motor, im getting the same cam and springs. but what about on nitrous, i have an 02. if it peaks at 6200, i could shift spraying at 6250 prolly and get by right? maybe be running a 3.73 tho, dont wanna run outta gear so would like to go as high as ya'll think it will hold.
Old 01-10-2005, 08:37 PM
hows that cam with the 3500 tci and 3.23's ??? or have u put in it yet? when u get it done let me know how it drives.
Old 01-10-2005, 09:48 PM
Caribe's Avatar
I have not put it in yet, waiting for a msd digital window switch for a nitrous kit going it at the same time. I' ll let you know. I am also getting it tuned on the dyno. Can you say 12 bolt
Old 01-11-2005, 05:20 AM
Nickn20's Avatar
please get an LS6 intake, lol. Are you gonna put the cam in yourself?
Old 01-11-2005, 10:20 AM
Caribe's Avatar
LS6 intake?(01 TA) My buddy owns a speed shop here, so we are going to install it there. Still debating between three places for my dynotune.
Old 01-11-2005, 07:55 PM
81LS1Camaro's Avatar
What is the stock rev limiter set at on a 98 z-28? I have a ls6 cam in it and am wondering where I should set the limiter.
Old 01-11-2005, 08:25 PM
2000bluess's Avatar
Im pretty sure Nick was talking about Jeremy's car (jermzz) because he doenst have a ls6 intake.
Old 01-11-2005, 10:16 PM
jermzz's Avatar
2.1, lol. I know the car will run faster (that was cam alone no heads or LT's ), that's why I didn't tell anyone I went. I really don't want anyone to know my times untill I get it finished for this summer and go again. Pluss it was my first time ever to the track.
Tranzor_Z28: I get it, that's still a hell of a run. I will be going form 3.73's and nittos to 4.11's in a 12 bolt and ET streets, maybe that's why i'm expecting such a jump in time. Thanks for the clarification though.
Nick: Yes I bought an intake aswell, I figured it was time for one and I AM putting it in myself, I did my heads, so why not? heh. I'll be calling you shortly for my tune though! -- hey, when I get my 12 bolt you can put it in, depending on how much you want to do it
Alright well it sounds like I can just leave the rev limiter where it is. If the dyno says it can go a little higher, maybe i'll have it set to 7, and shift at 6800.
Old 01-11-2005, 10:37 PM
jermzz's Avatar
BTW Costa, why do you have the Viper in YOUR sig? You don't see my sig with Mercedes SL500 Lorinser, or H1 Hummer. =p heh heh heh.
Actually, I went to the Mercedes dealership today with my parents. They drove the SL55 G-Wagon, I think they're gonna buy it. Man it hauls ***, its got almost 500 hp. lol
I took some pics of it and the SLR they had in the showroom, Check it out
Old 01-12-2005, 04:28 AM
greekss's Avatar
cuz it is in MY name.... especially after someone bapped it into the wall, its under my name, believe it or not its cheaper ins. that way.
Old 01-16-2005, 12:08 PM
1972chevelle454's Avatar
And the viper IS stock, not kinda. It still has the orginal tires from 94. You dont gotta lie to kick it costa.
