Cylinder head airflow question
I know that some companies like TEA flow their heads with a pipe attached to the exhaust port. How much does this effect the flow numbers?
it depends on the port some it helps a bunch others it helps a little. It all depends on how the port was developed. The next killer exhaust port I flow I will try the peak without a pipe and give you better answer.
