What therm R U running?
Old 01-14-2005, 12:19 PM
jub jub's Avatar
Default What therm R U running?
Just wondering what everyone is running in the way of thermostat?
You guys running the 160 stats, any adverse side effects that you know of?
Old 01-14-2005, 01:10 PM
VortechC5's Avatar
I have a 172 in mine now. I had a 160 and it ran colder (mid to upper 160s) than I wanted it to. I tried a 180 it ran almost the same temperature as stock.
Old 01-14-2005, 01:12 PM
00T\A's Avatar
160 here.
Old 01-14-2005, 01:17 PM
goober35's Avatar
160 here but i have an iron block.
Old 01-14-2005, 01:35 PM
nspr8td lt1's Avatar
160 t-stat and custom fan switch.
having a 160 deg t-stat and no computer changes or fan switch will only alter the temp at which your thermostat opens(letting the coolant flow) so in city traffic the temp will rise just like stock, but on the highway it will drop down significantly.
with a fan switch/ computer tuning you can keep it lower 24/7.
Old 01-14-2005, 02:40 PM
SmaknaSS's Avatar
160* here, Run's ~ 180*.
Old 01-14-2005, 02:51 PM
WicketMike's Avatar
160 stat and i run it about 178-182 with the fans on ls1 edit
Old 01-14-2005, 03:24 PM
Turo's Avatar
stock t-stat. lowered fan temps, i run at around ~190-200
Blacker's Avatar
160 Thermostat here.
Old 01-14-2005, 03:30 PM
Chris81's Avatar
Stock..
Old 01-14-2005, 03:58 PM
SSINFUL's Avatar
Down there in GA it doesn't ever get really cold, does it? Regardless of whatever other mods you have done, the vast majority of engine-builders would tell you to go 160 degrees. Just set your fan temps appropriately.
Are you just starting to build up?
Old 01-14-2005, 04:12 PM
68birdls1's Avatar
stock here as well, but i have my fans on a toggle switch and turn them on around 200 or so!
Old 01-14-2005, 05:47 PM
jub jub's Avatar
No my engine is done and has a 160 installed. It stays at 178 and that's as high as I've seen it go. I was just curious what everyone was using.
Old 01-14-2005, 06:00 PM
luv2spd's Avatar
I have stock thermo for now but i have my fan setting set to keep it below 200.
Old 01-14-2005, 07:44 PM
highgear's Avatar
I run the stock GM 186 degree stat. Cost was about $23. According to GM, this is where the motor is supposed to be most efficient.
Old 01-14-2005, 07:55 PM
PureWS6's Avatar
what is everyone using to set their fans to come on at a lower temp. without wiring up a remote fan switch
Old 01-14-2005, 08:09 PM
Turo's Avatar
tuning
Old 01-14-2005, 08:18 PM
VortechC5's Avatar
LS1Edit.
Old 01-14-2005, 08:19 PM
Mike98WS6's Avatar
160 stat with tuning.
Old 01-14-2005, 08:20 PM
11 Bravo's Avatar
I've never seen an aluminum block ls1 run faster/dyno higher with a colder than stock thermostat. Seen the opposite, actually.
