bigger cam than "MS3" without fly cutting
Old 01-18-2005, 04:43 AM
xxboomer408xx's Avatar
Lightbulb bigger cam than "MS3" without fly cutting
i was wondering if anyone was running a bigger cam than a TSP Magic Stick v.3 ("MS3") Camshaft: 237/242, .603"/.609", 113 LSA with stock heads on a stock bottom end without flycutting the pistons? seems like it is the biggest but i could be wrong.
Old 01-18-2005, 09:49 AM
ssfirefighter's Avatar
Juggernaut (G5x4) is bigger so they say.
Old 01-18-2005, 09:58 AM
hc_performance's Avatar
t-rex is bigger
Old 01-19-2005, 04:15 AM
do they have more lift?
Old 01-19-2005, 05:19 AM
Nate_Taufer's Avatar
t-rex? yes, juggernaut? I don't know.
Nate
Old 01-19-2005, 03:31 PM
BLASTER's Avatar
He said without flycutting. I believe the Trex requires a little notch and if the the G5x3 112 requires flycutting I am sure the Juggernaut does.
Old 01-19-2005, 04:11 PM
t-rex doesn't. It's right at about .080 p to v clearance. Im not sure about the juggernaut. And you can run the x3 on 112 w/o you are just pushing the envelope of what's safe.
Nate
Old 01-19-2005, 11:06 PM
CamaroCain's Avatar
why not just get the MS3? Makes great power and should work some good 1/4 mile times at the strip.
Old 01-20-2005, 02:35 AM
sr71bbjr's Avatar
We put a 240 244 598 608 115 in a auto the other day.Not a lot of lift but thats not all that effects p to v claerance.
Old 01-20-2005, 03:30 AM
well i was just wondering cuz i got a 236/242 601-610 lift on a 113 lsa so i wanted to know if i had to flycut my pistons, which i don't want to do!
Old 01-20-2005, 10:20 AM
NO5.0's Avatar
I know the g5x3 will fit on a 114 but not a 112 as told by lou @ LGs the g5x4 will require flycutting. Also depends on gaskets used. Im going to be running a g5x3 cam and AFR 205s and do not have to flycut. Hope that helps a little.
Old 01-20-2005, 10:23 AM
Louis's Avatar
The x3 112 does not require cutting on stock heads, stock valves, same with the X4 ( Juggernaut) Lift is 605+ on the X4.
Any deviation from stock parts will result in the need for flycutting.
Quick Reply: bigger cam than "MS3" without fly cutting
