If you have changed out your knock sensors, inside please
I'm getting the dreaded P0327 code. So I am going to change out both knock sensors and wire. I have the following parts numbers for a 2000 Z28,
2-10456603 Knock sensor
1-15372170 Wire
I have also found a part number for a "connector" that looks like it attachs at the top of the knock sensor. Do I need this? It's part number 12167120.
Do I have all the parts listed that I need? TIA
<img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
1-15372170 Wire
Re: If you have changed out your knock sensors, inside please
Hrm, the wire is built into the wiring harness for the car. Are you going to cut and splice in a new section?
If that new wire comes with the connector already attached (a lot of GM "wire repair kits" already come with the connector) then you wont need the extra connector. I don't know what that wire part # comes with though.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by jmX:
<strong> Hrm, the wire is built into the wiring harness for the car. Are you going to cut and splice in a new section?
If that new wire comes with the connector already attached (a lot of GM "wire repair kits" already come with the connector) then you wont need the extra connector. I don't know what that wire part # comes with though. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I got the wire part number off of a thread in the Diag section. On my parts CD, the part # 15372170 Wire, Knock sensor (includes)
-connector, sen knock
-connector, inline to eng harness
-clip, harness knock sensor jumper
-grommet, knock sensor
So I am guessing I need two knock sensors and two knock sensor "wires". to connect from the knock sensors to the engine harness? I'm just trying to get all the parts I need in advance so I don't have to make a mad dash to the parts store for something they may or may not have.
minivette,
Not to change the subject but where did you get that "Parts CD" that you mentioned?? I am interested in getting one if its available.
