Will this cam work without flycutting my pistons?
Specs are as follows
grind ls1 3349/3349 hr114.0 serial # v 4039
gross lift .581 .581
dur @.006 306 306
@.050 254 254
valve timing open close
@ .050 int 13 btdc 61 abdc
exh 61 bbdc 13 atdc
114 lsa
lobe lift .342
Also is that way to big for a 3500rpm stall?
Lift isn't all that big but it has a huge duration, what do you guys think?
dur @.006 306 306
@.050 254 254
exh 61 bbdc 13 atdc
114 lsa
lobe lift .342
Originally Posted by XtrmLS1spd
Yes it will. You do not have to flycut as long as you are running the stock heads. If you are running aftermarket heads, you wouldn't want to go over .598 or so and that's pushing it.
