Safe rod bolt/cylinder wall clearance
Old 01-20-2005, 07:45 PM
11 Bravo's Avatar
Question Safe rod bolt/cylinder wall clearance
I have Eagle rods w/ ARP bolts. The clearance with the Darton sleeve is very, very close. Not touching, but close. What is the proper spec supposed to be?
Old 01-20-2005, 08:59 PM
Under criminal investigation for fraud
Chris@AP-Engineering's Avatar
You should be shooting for around .060" on anything that is rotating. If you have that much or more you will be fine.
Thanks
