Fired Up 370ci APE For First Time!!!
BUT I have a couple of questions . . . the car seems normal for I'd say the 1st 20-30 seconds . . . then the blue smoke starts rolling out. Continues for about 5 minutes and then stops ( whether I'm driving or just idling ). At the same time the smoke starts, the idle of the car changes. The motor has a total of I'd say 35 miles on it so far. Plus it only seems to smoke when it is stone-cold, like overnite, or all day at work in the parking lot.
I am going to pull the hose off the butt-pipe to check for oil, any other things I should be keeping an eye out for? I know a new motor will smoke for a while, but how long is too long?
- Dug
- Dug
Well, this is definitely coming OUT of the exhaust, it definitely appears to be oil burning from the motor . . . I did have OTHER smoking, like from the engine until all the crap burned off, but this is different.
Under criminal investigation for fraud
Doug, do you have the turbos onit right now? Also if the smoke stops, after like 5 minute and seems to be worse after sitting over night, it could be valve seals. Give me a call and we can try to figure it out together.
Thanks,
Thanks,
Hmmm, just got off the phone with Chris, I think he could be right about the valve seals . . . sitting overnite the oil drips onto the piston, that's why it burns off and then no more. Anybody else??
- Dug
- Dug
Justin, are you sure about the 1000 miles?? I was thinking 500 would be plenty . . . and if it were the rings they wouldn't just smoke for 5 minutes, wouldn't it be an ongoing thing?
- Dug
- Dug
This y it is so hard to figure out what is going on in a motor. The only reason it could be the rings is when it is cold metal shinks so you have a looser bottom ring in there. Once it heats up it would go away.
I have always been told 1k for ring seat. I bet 500 is enuff but i would like to make sure before romping on the car because if the rings dont seat properly you can have the problem that u are having now.
Originally Posted by goober35
all this talk about 370's just make me want to go and drop mine in today instead of waiting untell tommarow.
- Dug
- Dug
P.S.: I had no smoking whatsoever with mine. Something must be wrong with your setup. Hopefully, it will no be too bad. I hope for you that it's just the valve seals.
Best of Luck Dug!
P.S.: Awesome numbers!!!
