Problem: When Dynoing Coolant Started To Overflow From Resevoir Twice?
Originally Posted by SICKBIRD
When Dynoing Coolant Started To Overflow From Resevoir Twice? What Can Cause This?
Originally Posted by Full-Force
blowed head gasket will put build compression in the cooling system
mine did that with my first aftermarket resevoir cause it did not have a return pipe so It would fill up the resevoir and once full just spit it out the top when the car got hot . I'm assuming you still have the stocker so is the fluid going up and down in the resevoir? should be down when cold and full when hot. Or is it always full?
