super high RPM hydrolic cam
Old 04-22-2003, 11:41 AM
Terry Burger's Avatar
Default super high RPM hydrolic cam
I'm toying with the idea of going for the cam only record (10.99 now right?). What kinda cam would I need for super high RPM action? I'm thinking something like a 232/232 114ls. Any other ideas? Narrow power band is OK.
Old 04-22-2003, 01:12 PM
ONEBADWS6's Avatar
Default Re: super high RPM hydrolic cam
01-Z should have that record beat tonight, G5X-2 is an awsome cam.
Old 04-22-2003, 01:43 PM
The Juggernaut's Avatar
Well...I'm trying anyway. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
LG will sell you the cam,they don't have to install it.
Speed Inc. installed mine.
Old 04-22-2003, 01:59 PM
JS
JS's Avatar
Hey that was my idea too..
Terry u stole my idea <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Good luck 01....
JS
Old 04-22-2003, 02:22 PM
DONAIMIAN's Avatar
Who set that record for the fastest cam only car. What was the race weight on it <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old 04-22-2003, 02:26 PM
MastaAce98's Avatar
You plan on running an aftermarket piston, or are you going to keep this strictly a bolt-on type application?
If I were you I'd run an aftermarket piston, something pretty high compression, and a shorter rod (not MUCH shorter, just a few thousandths of an inch). Then I'd make sure the heads would be able to flow what the cam needed, and then run a Comp-R lifter and rev it to 7500/7600.
Don't go the solid roller route unless you know what you're doing. You can slow your car down substantially.
Old 04-22-2003, 02:28 PM
MastaAce98's Avatar
Oh and by the way.... just for conversation.
7200rpm is NOT "super high" rpm.
Old 04-22-2003, 02:43 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Not sure yet, but I might wind up with stock replacement forged pistons (at stock CR). I'd love to get the CR up but I think that's "cheating". I don't think any cam in an LS1 with stock heads is going to make power to 7600, not even a solid roller, but 7200 seems possible. Down the road I might add ported 5.3 heads with light weight LS6 valves.
Old 04-22-2003, 02:49 PM
TreeGreenZ's Avatar
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Whats the matter with Solid Roller <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old 04-22-2003, 02:53 PM
MastaAce98's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by TreeGreenZ:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Whats the matter with Solid Roller <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I never said anything was wrong with it. I just said that if you don't know what you're doing, you'll probably get pissed because your car ran a lot slower than you expected. I've seen it happen a hundred times.
Old 04-22-2003, 03:17 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
IMO it has to have a stock bottom end with maybe ARP rod bolts, Hoffpauir has a bone stock bottom end I think.
Old 04-22-2003, 03:20 PM
Fenris Ulf's Avatar
If you are going with a G5X2, just get a comp XE-R 232/240 on a 114 with like 2-4 degrees of advance. The G5X2 has like 7 or more degrees of advance ground in per LGs specs.
Old 04-22-2003, 03:37 PM
HP-GURU's Avatar
Extend your powerband by increasing duration, not by widening LSA. I think for a record on stock headed car, the LSA will be narrow.
Old 04-22-2003, 03:38 PM
Moderator
xp3nd4bl3's Avatar
BIIIIIG dood!
Old 04-22-2003, 03:40 PM
I want a high RPM narrow power band. Say 6200-7200rpm. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old 04-22-2003, 04:32 PM
gwj
gwj's Avatar
Location: Live Oak, FL - in the woods where the creatures lurk.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Tin Indian:
<strong> Topic: "super high RPM hydrolic cam"
Terry, it's spelled "Hydraulic" <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Sorry, I don't have a good answer to your question.
Ron,
Spelling Teacher </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Sorry, off topic here. Good to see you back in the World, Ron. I'm sure your vehicle has seen some hard acceleration, as the two of you get re-aquanted after all this time!
Gerald,
Non-spelling checker. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old 04-22-2003, 04:34 PM
gwj
gwj's Avatar
I guess that was literal, as I seem to have left the "i" out of acquainted! Duh!
Old 04-22-2003, 04:45 PM
TreeGreenZ's Avatar
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Ya I understand that, I was just wondering what am I gonna screw up, so that mine doesn't run that well???? Right now I am only seeing like 18 degrees of timing at WOT, adn I am little lean, I am gonna go to the track here soon, hopefully I can run this tune, then run a new tune and see what happens.....Hopefully good things. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old 04-22-2003, 07:24 PM
DailyAluminumBlock's Avatar
Narrow LSA would surely help. Try a G5-X2 related duration cam on xe-r lobes with a 108-110lsa.
Old 04-22-2003, 08:14 PM
Tin Indian's Avatar
gwj .....
Well, thankyou so much. Yes, back in the good ol' US of A.
I retire from US fed civil service in 7 more months. Thinking about moving to Pattaya Beach, Thailand.
Here we go again..... <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Ron,
