eagle stroker kit in summit racing
Old 01-25-2005, 11:23 AM
MARKSZ71's Avatar
Default eagle stroker kit in summit racing
just got my new copy, $2600 for a eagle stroker kit 383 cubes je pistons h beam rods doesnt sound to bad a deal
Old 01-25-2005, 11:31 AM
zamboxl's Avatar
yea saw that to but eagle cranks are kinda not to good or proven yet
Old 01-25-2005, 11:36 AM
jrp
SN95 Director
jrp's Avatar
the first batches had some issues but as far as i know they've rectified them. plenty of people running eagle cranks now.
Old 01-25-2005, 11:39 AM
smokinHawk's Avatar
does summit or jegs have the single plane intake yet?
Old 01-25-2005, 12:01 PM
DAPSUPRSLO's Avatar
I saw that too, looks like a hell of a deal. I think Eagle's initial problems were involving clearencing the weights of the crank, not sure though.
Old 01-25-2005, 12:31 PM
Timberwolf's Avatar
jegs has the stroker kits for 2300 and they also have the single plane intakes I believe
Old 01-25-2005, 12:55 PM
8 Sec Builder
The Machinist's Avatar
We run Eagle cranks and rods in our motors and also Scat rods. We haven't had any major problems with them so far. I ran into a small problem when you run a 4.00 Eagle crank and Mahle pistons, when the piston goes to BDC the crank will hit the piston because the bottoms of the pistons are straight on the pin boss where as the Wiseco are rounded.
Old 01-25-2005, 01:10 PM
LT99LS1's Avatar
You can buy the same kit for less money from the some of the sponsors on here. I paid $2000 shipped for my kit and I got a custom pistons.
Old 01-25-2005, 01:56 PM
MrDude_1's Avatar
what sponsor did you order it from for that deal?
Old 01-25-2005, 02:09 PM
LT99LS1's Avatar
Keith Craft Motorsports,not sure if they are still a sponsor on here.http://www.keithcraftmotorsports.com...ngines_ls1.asp
Old 01-25-2005, 02:21 PM
zamboxl's Avatar
i thougth that eagle cranks were not balanced, and you had to spend like $700 to balance them, wich is why i think lingenfelter or some of the other sponsors used cali cranks over them. pls correct me if iam wrong!!
Old 01-25-2005, 02:36 PM
LT99LS1's Avatar
It cost me $145 to have everything balanced.
Old 01-25-2005, 02:37 PM
zamboxl's Avatar
damn not bad
Old 01-25-2005, 03:29 PM
DAPSUPRSLO's Avatar
I believe the kit sais it is balanced in Jegs. They have been known to misquote information before though.
Old 01-25-2005, 03:59 PM
SSean's Avatar
Damn, $700 for a balance? Thats almost the price of the crank itself. I got my kit from TSP which was able to price match Keith Craft. They claim to come internally balanced, but I had a machine shop balance mine, cost around $120, on top of $2100 for the rotating assembly (eagle crank, rods, and JE pistons). Been running this set-up for a few months now and do not have any problems what so ever. No clearance issues, no balance issues, no oil consumption, and more power than my street tires know what to do with :p
Assembled the motor myself as well, only modification I had to do was putting a little notch in the excess aluminum under the sleave where the ARP rod bolt might hit, nothing major. I'd go with eagle again with out thinking twice!
Old 01-25-2005, 04:12 PM
LT99LS1's Avatar
Correct on all counts. Hijack thread coming on.What Throttle body/MAF did you go with? Got any dyno numbers and if so what kind of dyno?
Old 01-25-2005, 04:46 PM
Bo White's Avatar
Good price for the Eagle kit is 2200 bucks or less and average balance job cost is 150-175.
Old 01-25-2005, 05:10 PM
SSean's Avatar
I've actually got the car running pretty good MAFless, but have the stock MAF plugged in right now. I might either go with an LS6 85mm MAF, or just delete the MAF completley, and get some good sized hose or bellows of some sort to connect to the TB. I'm running the stock intake and TB now, but hope to upgrade to 90mm stuff soon More questions answered here https://ls1tech.com/forums/showthrea...23#post2365023
Old 01-25-2005, 07:24 PM
MOTRUBL's Avatar
Anyone think that the Eagle 408 kit will hold a 100 dry and a 150 wet 2 stage N2O setup??
Old 01-25-2005, 07:30 PM
ktmrider's Avatar
Another satisfied Eagle user. Also ordered thru Keith Craft for $2000 shipped with custom pistons.
Quick Reply: eagle stroker kit in summit racing
