change in cam choice
Old 01-25-2005, 04:36 PM
NO5.0's Avatar
Default change in cam choice
Originally decided on AFR 205s and G5X3 but have to flycut pistons unless go with the 66cc head. Tony @ AFR suggested to go with a smaller cam and mill the head to 61-62cc for more compression. That would make a better combo. My question is what cam will yield the best combo, power being the most important issue? Ive seen the 224/228 in Tonys combo, looks good. Ive seen 226/230 XER in one of Norris motorsports cars that also looked good. I was wondering about the 233/239 ? Will it clear and how about the combo for power w/AFRs. Another ? what if I had the heads at 65cc with the G5X3 it would still have to put out more power than a stock headed G5X3 car which I saw produce over 400? Any input would really help seeing Im ready to purchase something so I can get started to making more power! THANKS AGAIN!!!!!!!!
Old 01-26-2005, 12:23 AM
NO5.0's Avatar
Any Input????????
Old 01-26-2005, 12:32 AM
pdd
pdd's Avatar
my setup i have my afrs milled .024 with the fm14. my CR is 11:1. also i had to flycut
Old 01-26-2005, 12:38 AM
NO5.0's Avatar
any dyno #s? who did the flycuuting? ive never done it so trying to get some input if i should attemptr it or leave alone and settle for a smaller cam?thanks
Old 01-26-2005, 12:45 AM
pdd
pdd's Avatar
i rented the flycutter from TEA and did it myself with the engine in the car. its time consuming but very doable. no dyno numbers yet as we are buried in snow up here
Old 01-26-2005, 12:50 AM
NO5.0's Avatar
What does the tool consists of? How did you measure how much to notch? Also u may have had a little more room on the C5 than on my SS. By the way where u at with all the snow? Detroit got a good amount but east i heard got a lot more!
Old 01-26-2005, 01:50 AM
jrp
SN95 Director
jrp's Avatar
your back to square one with the 233/239 as it will not clear the milled heads. if your going to flycut just stick with the x3. i vote fly cut and run the x3 or dont fly cut and run a smaller cam since compression is your friend. obviously even with the stock chambered afr's and an x3 you'll make a ton more power then an x3 cam only.
Old 01-26-2005, 09:17 AM
NO5.0's Avatar
THANKS JRP I think youre right but how much of a PITA is flycuttin while the motor is still in the car and half under the firewall? If i end up going that route i will probably go with the 225s and G5X3. Anyways thanks again for the input.
Old 01-26-2005, 09:53 AM
jrp
SN95 Director
jrp's Avatar
http://forcefedhighperformance.com/tech_Isky.htm
Old 01-26-2005, 11:15 AM
NO5.0's Avatar
jrp appriciate the info, where do you find all this stuff? Now I just have to find a mock up head? Thanks again!
Old 01-26-2005, 11:19 AM
jrp
SN95 Director
jrp's Avatar
i find it by searching
whats the rest of the setup gonna be, i dont remember off hand.
Old 01-26-2005, 11:47 AM
NO5.0's Avatar
AFR 205s, G5X3, LS6 intake,ported tb,lngtubes, slp cat back, 410 gear. by the way i cant use a regular ls1 head to flycut cuz im changing to the afr right? Can i still make decent pwr with the afrs at 66cc and the g5x3?
